Blade Fusion 180 BNF Basic
Fusion series improvements and refined control make this micro heli fly like nothing before. It's practically in a class by itself.
High Performance 3D for your Backyard
The Fusion styling revision adds a redeveloped lightweight and extremely rigid carbon fiber main frame. Plus, the new belt-driven tail and newly developed tail case improve tail performance and overall durability. Hosting this new belt is an over-sized tail boom large enough to eliminate the need for boom supports. With this new tail design, the tail servo has moved to a more discrete location mounted to the tail.
Optimized servo geometry greatly reduces mechanical loss and improves control efficiency to the swashplate. Driven by Spektrum™ metal gear servos, pilots are sure to appreciate the precise control. Painted carbon fiber tail fin finishes off the sleek styling of the Fusion redesigned canopy. A new 20 Amp ESC offers improved, precise head speed control for that high performance flight that doesn't lag behind. With BNF® Basic convenience, all you have to do is add a 4S 450mAh battery, bind your 6+ channel Spektrum DSMX® transmitter, and you're off to hit all the hurricanes, tic-tocs, and detonators in your arsenal.
Check out the Blade Fusion 180 BNF Basic Here
Jun 08, 2019, 09:38 AM
Why do they always show a Hot Shot 3D pro Pilot flying these things?, they make it look so easy!... why don't they just show a average Joe Smoe flying and crashing, picking it up off the floor with the look of Disgust!...
Jun 08, 2019, 02:14 PM
Because it's designed as an expert level helicopter? the 180CFX on 3s is serious handful until you get used to it... the Fusion 180 is that and more with a stretch and 4s power. it doesn't even have stability mode, so.... definitely not designed for a novice. they have the 130S in this size range for those that would prefer a heli that can hold up to crashes, and it will fly mild 3d quite well as a learning tool on the way to expert...
Jun 08, 2019, 02:25 PM
Folding Spacetime
navigator2011's Avatar
For reals. I remember a video by Blade where they intentionally crashed a 130s just to demonstrate how well it holds up.
Discussion Blade Fusion 180 BrokeDad Micro Helis 206 Jan 19, 2020 10:33 PM
Article Horizon Hobby UMX Habu 180 DF BNF Basic kevin Micro EDF Jets and Power Systems 22 Mar 26, 2019 06:35 AM
News Blade 250 CFX BNF Basic With SAFE Technology ndfly700 Electric Heli Talk 216 Aug 28, 2018 12:18 PM
News Blade 180 CFX BNF Basic ndfly700 Micro Helis 17 Mar 09, 2015 04:30 PM
