This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Jun 03, 2019, 06:54 AM
Merch's Avatar
Mini-Review
Eachine RedDevil 105mm 2-3S FPV Racing Drone PNP/BNF Crazybee F4 PRO Caddx EOS2
https://www.banggood.com/Eachine-RedDevil-105mm-2-3S-FPV-Racing-Drone-Whoop-PNPBNF-Crazybee-F4-PRO-Caddx-EOS2-5_8G-25200mW-Nano-VTX-p-1491992.html
Eachine RedDevil 105mm 2-3S FPV Racing Drone Whoop Crazybee F4 PRO Caddx EOS2 5.8G 25~200mW Nano VTX
Specifications:
Brand Name: Eachine
Item Name: Red Devil 2-3S Micro FPV racing drone
Wheelbase: 105mm
Size: 95mm*95mm*50mm(without propellers)
Weight: 38g(without battery)
Weight:63g(with Original 3s 300mah Lipo battery )
Spare parts specifications:
Motor Mode: EX1102 KV8700
Configu-ration:9N12P
Stator Diamter:11mm
Stator Length:2mm
Shaft Diameter:Φ1.5mm
Motor Dimension(Dia.*Len):Φ13.5mm*16mm
Weight(g):2.8g
No.of Cells(Lipo):2S-3S
Flight controller (Frsky version) CRAZYBEE F4FR PRO V2.1 Firmware target: CrazybeeF4FR
(Flysky version) CRAZYBEE F4FS PRO V2.1 Firmware target: CrazybeeF4FS
(DSM2/DSMX version) CRAZYBEE F4DX PRO V2.1 Firmware target: CrazybeeF4DX
(No RX version) CRAZYBEE F4 PRO V2.1 Firmware target: CrazybeeF4DX
MCU:STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 2-3S battery input (DC 7.4-13V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Frsky version Built-in SPI Frsky receiver with telemetry(D8/D16 switchable)
Flysky version Built-in SPI Flysky receiver with telemetry(AFHDS/AFHDS2A switchable)
DSM2/X Version built-in Serial-based DSM2/DSMX compatible satellite receiver
No RX version need to add external Receiver
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 28A
Current meter scale set to 1175
Built-in 5V 1A BEC with LC filter
Built-in voltage detection
Onboard 4in1 ESC MCU upgraded to EFM8BB21
Power supply: 2-3S LiPo/LiPo HV (7.4v/13v)
Current: 5A continuous peak 6A (5 seconds)
Support BLHeliSuite programmable
Factory firmware: S_H_50_REV16_7.Hex
Default protocol: DSHOT600
Frsky receiver Version SPI BUS receiver
Frsky D8/D16 switchable
Compatible both Non EU and EU-LBT transmitter Channels: 8ch or 16ch
EU-LBT support(need to update betaflght v4.0 date 2019-04-11)
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Flysky receiver Version SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
DSM2/DSMX receiver version Serial bus receiver
Protocol: DSM2/DSMX compatible
Channels:6-9 (Depend on your radio)
PNP No RX version No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc.
VTX Output power: 25~200mw switchable
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Antenna: RG178 antenna
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready
Weight: 2g
CADDX EOS2 camera 1/3" CMOS Sensor
1200 TVL
2.1mm lens
16:9 Image size
NTSC
Global WDR
Internal Synchronization
Lipo Battery Capacity:300mAh
Voltage:11.4v
Continuous Discharge Rate: 30C
Instantaneous discharge rate: 60C
Weight: 25g
Connector: XT30
Features:
Crazybee F4 PRO V2.1 AIO Flight controller 2-3s Lipo Compatible
The lightest 1102 brushless motor only 2.8g with double ball bearings
Light ,Powerful and smoothly
Caddx EOS2 ready
Camera angle adjustable
25mw-200mw 5.8g vtx with smartaudio
Betaflight OSD support ,easy to get RSSI, Voltage ,current from your goggles(DSMX version no RSSI output)
Frsky version support both NON-EU and EU-LBT Frsky transmitter(EU-LBT need to update firmware to Betaflight 4.0( release date :2019-4-11)
Flysky version support both AFHDS and AFHDS-2A protocol transmitter
DSM2/DSMX version support DSM2 and DSMX compatible Spektrum transmitter
No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc..
Full telemetry function ready (Frsky and Flysky version support)
Real Bind and Fly version
Package Included:
1 x 105mm Brushless whoop Frame
1 x Adjustable angle canopy
1 x Option1: Crazybee F4FR V2.1 PRO FC built-in Frsky RX
Option2: Crazybee F4FS V2.1 PRO FC built-in Flysky RX
Option3: Crazybee F4DX PRO V2.1 FC built-in Serial-bus DSM2/DSMX RX
Option4: Crazybee F4 V2.1 PRO FC no RX verion
4 x EX1102 KV8700 Motor
1 x 65mm red propeller(6xcw+6xccw)
1 x Caddx EOS2 camera
1 x 5.8g 25mw-200mw Nano VTX
1 x 3S 11.4v 300mah 30C/60C battery
1 x XT30 Plug Pigtail Power Wire with 100μF 16V Capacitor
1 x Propeller disassemble tool
1 x Screwdriver
1 x Eachine Handbag
Jun 03, 2019, 12:19 PM
chrys_burge's Avatar
These specs and components look great. Weight is 0.8 grams AUW heavier than the Sailfly-X.
Is there anything that should be modified for the full production version?
Jun 10, 2019, 04:36 PM
Merch's Avatar
Maybe put the capacitor on the board instead of on the XT30 plug and change the cam to a 4:3 aspect ratio instead of 16:9.
Jun 10, 2019, 05:09 PM
Agreed! Wish the cam was 4:3..
Sent from my SM-G975U1 using Tapatalk
Jun 10, 2019, 06:26 PM
BG had the expected date to be in stock June 12 for quite a while.
Now it's expected July 5th...
Jun 11, 2019, 01:55 AM
Merch's Avatar
Maybe they are making some changes for the better
Jun 17, 2019, 10:18 AM
Just saw this, this morning. Summer Prime sale??
https://www.banggood.com/Summer-Prim...r_warehouse=CN
Jun 18, 2019, 08:25 AM
Looks like the FRSKY and FLSKY versions are currently in stock on BG.
Just paid for (2) FRSKY versions.
Jun 18, 2019, 10:17 AM
Merch's Avatar
Summer sale maybe means there will be a big discount after you have ordered the one you did lol.
Jun 18, 2019, 10:18 AM
Ha! Probably..
Jun 27, 2019, 03:11 PM
Merch's Avatar
The wait begins
Jun 27, 2019, 03:40 PM
Mine should be here by 7/11.
Looking forward to checking it out!
Jun 28, 2019, 09:26 PM
Merch's Avatar
Nice!
Jul 07, 2019, 11:36 PM
Merch's Avatar
Updated with some pictures full review to follow wow i have my hands full
Oct 09, 2019, 06:44 PM
Merch's Avatar
Thanks to a fellow Scots ptwenty for printing me out some canopys,yet to take it out for a test flight tho.....I ow you a pint m8
New Product Eachine Trashcan 75mm Crazybee F4 PRO OSD 2S Whoop FPV Racing Drone Caddx Eos2 Merch Micro Multirotor Drones 427 Aug 19, 2019 08:02 AM
New Product Supra7 Pro 75mm F4 OSD 2-3S Cinewhoop FPV Racing Drone PNP BNF w/ 200mW VTX CADDX Tur Frimen Micro Multirotor Drones 4 Apr 13, 2019 08:58 AM
