Jun 03, 2019, 06:40 AM
Merch's Avatar
Eachine RedDevil 105mm 2-3S FPV Racing Drone PNP/BNF Crazybee F4 PRO Caddx EOS2
https://www.banggood.com/Eachine-RedDevil-105mm-2-3S-FPV-Racing-Drone-Whoop-PNPBNF-Crazybee-F4-PRO-Caddx-EOS2-5_8G-25200mW-Nano-VTX-p-1491992.html
Eachine RedDevil 105mm 2-3S FPV Racing Drone Whoop Crazybee F4 PRO Caddx EOS2 5.8G 25~200mW Nano VTX
Specifications:
Brand Name: Eachine
Item Name: Red Devil 2-3S Micro FPV racing drone
Wheelbase: 105mm
Size: 95mm*95mm*50mm(without propellers)
Weight: 38g(without battery)
Weight:63g(with Original 3s 300mah Lipo battery )
Spare parts specifications:
Motor Mode: EX1102 KV8700
Configu-ration:9N12P
Stator Diamter:11mm
Stator Length:2mm
Shaft Diameter:Φ1.5mm
Motor Dimension(Dia.*Len):Φ13.5mm*16mm
Weight(g):2.8g
No.of Cells(Lipo):2S-3S
Flight controller (Frsky version) CRAZYBEE F4FR PRO V2.1 Firmware target: CrazybeeF4FR
(Flysky version) CRAZYBEE F4FS PRO V2.1 Firmware target: CrazybeeF4FS
(DSM2/DSMX version) CRAZYBEE F4DX PRO V2.1 Firmware target: CrazybeeF4DX
(No RX version) CRAZYBEE F4 PRO V2.1 Firmware target: CrazybeeF4DX
MCU:STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 2-3S battery input (DC 7.4-13V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Frsky version Built-in SPI Frsky receiver with telemetry(D8/D16 switchable)
Flysky version Built-in SPI Flysky receiver with telemetry(AFHDS/AFHDS2A switchable)
DSM2/X Version built-in Serial-based DSM2/DSMX compatible satellite receiver
No RX version need to add external Receiver
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 28A
Current meter scale set to 1175
Built-in 5V 1A BEC with LC filter
Built-in voltage detection
Onboard 4in1 ESC MCU upgraded to EFM8BB21
Power supply: 2-3S LiPo/LiPo HV (7.4v/13v)
Current: 5A continuous peak 6A (5 seconds)
Support BLHeliSuite programmable
Factory firmware: S_H_50_REV16_7.Hex
Default protocol: DSHOT600
Frsky receiver Version SPI BUS receiver
Frsky D8/D16 switchable
Compatible both Non EU and EU-LBT transmitter Channels: 8ch or 16ch
EU-LBT support(need to update betaflght v4.0 date 2019-04-11)
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Flysky receiver Version SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
DSM2/DSMX receiver version Serial bus receiver
Protocol: DSM2/DSMX compatible
Channels:6-9 (Depend on your radio)
PNP No RX version No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc.
VTX Output power: 25~200mw switchable
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Antenna: RG178 antenna
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready
Weight: 2g
CADDX EOS2 camera 1/3" CMOS Sensor
1200 TVL
2.1mm lens
16:9 Image size
NTSC
Global WDR
Internal Synchronization
Lipo Battery Capacity:300mAh
Voltage:11.4v
Continuous Discharge Rate: 30C
Instantaneous discharge rate: 60C
Weight: 25g
Connector: XT30
Features:
Crazybee F4 PRO V2.1 AIO Flight controller 2-3s Lipo Compatible
The lightest 1102 brushless motor only 2.8g with double ball bearings
Light ,Powerful and smoothly
Caddx EOS2 ready
Camera angle adjustable
25mw-200mw 5.8g vtx with smartaudio
Betaflight OSD support ,easy to get RSSI, Voltage ,current from your goggles(DSMX version no RSSI output)
Frsky version support both NON-EU and EU-LBT Frsky transmitter(EU-LBT need to update firmware to Betaflight 4.0( release date :2019-4-11)
Flysky version support both AFHDS and AFHDS-2A protocol transmitter
DSM2/DSMX version support DSM2 and DSMX compatible Spektrum transmitter
No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc..
Full telemetry function ready (Frsky and Flysky version support)
Real Bind and Fly version
Package Included:
1 x 105mm Brushless whoop Frame
1 x Adjustable angle canopy
1 x Option1: Crazybee F4FR V2.1 PRO FC built-in Frsky RX
Option2: Crazybee F4FS V2.1 PRO FC built-in Flysky RX
Option3: Crazybee F4DX PRO V2.1 FC built-in Serial-bus DSM2/DSMX RX
Option4: Crazybee F4 V2.1 PRO FC no RX verion
4 x EX1102 KV8700 Motor
1 x 65mm red propeller(6xcw+6xccw)
1 x Caddx EOS2 camera
1 x 5.8g 25mw-200mw Nano VTX
1 x 3S 11.4v 300mah 30C/60C battery
1 x XT30 Plug Pigtail Power Wire with 100μF 16V Capacitor
1 x Propeller disassemble tool
1 x Screwdriver
1 x Eachine Handbag
Jun 03, 2019, 07:43 AM
alex_nikiforov's Avatar
Clone Happymodel Sailfly-X
Jun 03, 2019, 08:19 AM
Merch's Avatar
Yes but upgraded we were all waiting for it..........I will review it soon
Happymodel Sailfly X Review And Test Flight (17 min 5 sec)
Jun 04, 2019, 10:32 AM
Fan of just about anything RC
SoloProFan's Avatar
You really hit the jackpot, seems there is no release that passes you by. Happy for you, just hoping occasionally there will be some "crumbs" left for old guys like me.
Latest blog entry: For the love of the hobby!
Jun 04, 2019, 10:54 AM
Merch's Avatar
Thanks but this is not a sample i'm buying it just like the Sailfly........Err am i not older than you?............and it's my birthday soon too a good ol 47
Jun 04, 2019, 11:20 AM
SoloProFan's Avatar
I thought it wasn't available yet for order, so I assumed you mentioning reviewing it soon meant you were getting a free sample.
As for age, it's just a number, right? Until one day you wake up and notice getting out of bed isn't going as smoothly as years earlier.
Jun 05, 2019, 02:13 AM
Merch's Avatar
Everyones definition of soon is different my guess is it will be ready for shipping by the 12th or for preorder.
Getting up in the morning has nothing to do with age for me as you know..........are you saying it's not smooth for you getting out of bed
Jun 05, 2019, 03:33 AM
SoloProFan's Avatar
Soon is indeed a fuzzy indication. But it can be tricky to rely on pre-order shipping date indications, these tend to be very "flexible" to put it mildly.
Actually I don't sleep into the day often, usually I'm awake at first light, and get downstairs, make a coffee, and check RCG, then eat and start with that day's activity, work or other things.
Back to the Red Devil, I hope the added features like the VTX don't push the weight up so it will handle differently than the Sailfly-X. That one really hits a sweetspot, it rips so nicely. Just wish it would be more silent at high throttle.
Jun 05, 2019, 03:48 AM
Merch's Avatar
If you look close i can see that under the camera they have some kind of rubber dampning to stop the jello if i'm right.....The cam will get switched out for a 4:3 aspect ratio one as 16:9 is horrible to fly at fast speeds.
Jun 29, 2019, 05:39 AM
Merch's Avatar
LITTLE DEVIL! - Eachine Reddevil Toothpick 3S Fpv Quad - FULL REVIEW 😈🔥 (19 min 40 sec)
Jul 01, 2019, 05:40 AM
Merch's Avatar
KebabFPV review.
Eachine - Red Devil (yes it's almost the same...) (9 min 37 sec)
Jul 07, 2019, 11:40 PM
Merch's Avatar
Already swapped the cam out for a 4:3 aspect ratio one review to follow.
New Product Eachine Trashcan 75mm Crazybee F4 PRO OSD 2S Whoop FPV Racing Drone Caddx Eos2 Merch Micro Multirotor Drones 427 Aug 19, 2019 08:02 AM
Discussion FullSpeed Toothpick F4 OSD 2-3S Whoop FPV Racing Drone PNP BNF w/ Caddx Micro F2 1200 Merch Banggood.com 12 Jul 16, 2019 03:11 PM
New Product iFlight Cinebee 4K 107mm F4 OSD 2-3S Whoop FPV Racing Drone PNP BNF w/ Caddx.us Tarsi scousethief Banggood.com 0 May 22, 2019 05:53 AM
New Product Supra7 Pro 75mm F4 OSD 2-3S Cinewhoop FPV Racing Drone PNP BNF w/ 200mW VTX CADDX Tur Frimen Micro Multirotor Drones 4 Apr 13, 2019 08:58 AM
New Product Supra7 Pro 75mm F4 OSD 2-3S Cinewhoop FPV Racing Drone PNP BNF w/ 200mW VTX CADDX Tur alex_nikiforov Banggood.com 0 Apr 12, 2019 06:16 AM
