Jun 18, 2019, 11:51 PM
Here's a mash up of my two flights from the day. I like pop tops with this jet if you can't tell.
FMS Futura V2 -The Day's Flights (4 min 54 sec)
Jun 19, 2019, 01:34 PM
After I crashed my FW Avanti last year I've been looking for a replacement. It's between this, another Avanti, and the new Havoc Xe. I just watched a bunch of YouTube videos, and the wing control connectors are the winning factor. Suppose they'll last, long term? If I plug/unplug often?
Jun 19, 2019, 08:47 PM
HellHathNoFury's Avatar
Weather was awesome today & allowed another 5 flts on this beauty .. Refined GG & Flaps to my liking .. Found enough Kahunas to Snap Roll today & found I had to increase Ailerons to 135% to Snap otherwise it was a Lame Duck with Stock 100% ..For me Neck to Neck favouritism with the Avanti the more I fly it..
Jun 19, 2019, 09:15 PM
fairplane's Avatar
Awesome! So where did you end up for C/G? Youíre using a separate bec arenít you?
Jun 19, 2019, 09:54 PM
Originally Posted by fairplane
Awesome! So where did you end up for C/G? You’re using a separate bec aren’t you?
Exactly where the rear edge of the plastic wing connector is..Yes to the Bec..
Jun 22, 2019, 06:33 PM
Nick Radle
Bodywerks's Avatar
Got my V2. So far not much different than the V1 as far as assembly goes. One thing I changed immediately was the battery straps. The factory ones are too small for the larger, high C packs.
Might bolt the stab on before work to see if the fixed the crooked stab issue.
Jun 26, 2019, 11:25 AM
Nick Radle
Bodywerks's Avatar
Definitely not much difference in the quality improvement area. Screws still suck, battery straps are still too short for big batteries, and stab is still crooked in relation to the wing.
Jun 26, 2019, 02:08 PM
The screws most definitely suck! My friend unfortunately crashed his FMS plane and I immediately swooped in and claimed the wing screws because mine were already starting to strip!
One of the reasons I got this plane is because it looked like the wings come off easily for storage, so far they come off but not easily.
Jun 26, 2019, 02:12 PM
RC Addict
Crashed our Avanti S today. Need to decide between another Avanti or this. It sounds like quality might be a little better over on the Freewing? I really like the look of this Futura though.
Jun 26, 2019, 02:30 PM
Nick Radle
Bodywerks's Avatar
No, it's worse. Freewing quality is FAR superior. But this jet is faster.
Jun 26, 2019, 03:04 PM
One of the reasons I got this plane is because it looked like the wings come off easily for storage, so far the come off but not easily.
The wing screws definitely suck .. FMS should have made the hex groove deeper or used Phillips screws like Freewing .. Regarding taking wings off .. Try taking off right side up.. May come off easier that way..
Jun 27, 2019, 03:58 PM
Quest for Speed!!!
Mike_eee's Avatar
Amps?
Has anyone measured the AMPS the new 2100 KV set up pulls on the stock 100 A esc .
I am trying to use this set up using a freewing 100 A esc , wondering if the ESC is enough to handle this hot motor .
is this motor set to low timing ? 4-6 degrees , since its a 4 pole?
MikeRC
Jun 27, 2019, 04:43 PM
MikeRC
I read that they come set to medium, I checked mine and indeed it was set to med. Changed it to low with my hobbywing programming card.
Jun 27, 2019, 04:46 PM
I always takeoff right side up
Jun 27, 2019, 05:24 PM
I would hope so otherwise youíre in a whole lot of trouble..
Discussion FMS 80MM Futura sport Jet--NEW FMSmodel Foamy EDFs 1560 Aug 29, 2019 12:33 PM
Discussion FMS Futura 80mm EDF Jet Thetrums117 Electric Ducted Fan Jet Talk 6 Feb 03, 2019 12:53 PM
Discussion Freewing Avanti 80 or Fms Futura?🤔 havanacore Foamy EDFs 4 Oct 20, 2018 02:01 AM
Discussion Freewing Avanti S 80mm vs FMS Futura 80mm vs Freewing Stinger 90 90mm tommyt Foamy EDFs 3 Apr 22, 2018 04:44 PM
News FMS Futura PNP 80mm EDF Matt Gunn Foamy EDFs 2 Jan 19, 2017 01:03 PM
