A cheap 32 bit diy ESC, and firmware
Its been a while since I have put out any new hardware. The main reason is writing the firmware was much more time consuming than I first thought. Here is another very simple esc schematic. This would be very similar to the "typical" 32 bit esc using the stm32f051 processor and the fortior fd6288 chip. This one has no current sensing or anything fancy. Just a real basic design.
It is a two layer board.. can be printed cheaply at any pcb fab. The total cost for the parts is about 5-6 dollars using the nexperia psmn2r4 mosfets. It can handle a decent current.. not sure yet what the limit is but I have used the mosfets for many designs now and they work well for the typical load a 3 or 4 inch quad puts on them anyway. The firmware to use for the esc current can be found here.. https://github.com/AlkaMotors/AM32-M...r-ESC-firmware Another version of the firmware done by a talented individual with added commercial board support and structure clean up can be found here : https://github.com/3x8/nostromo/releases/tag/v1.2.2 The pinout is a little different but his can more easily support additional targets so should be fairly easy to set up. (proshot only for this version for now). There is no configuration tool yet so settings can be changed using dshot commands for rotation direction or 3d mode. Attached will be a zip file, there are gerbers and driptrace design files inside that can be opened with the freeware version of diptrace. I have a few more simple designs coming as they get tested. I have been using this one for a little while and have a few test flights on a 4 inch quad with 1806 motors. Edit 2020 : I finally have a patreon account, anyone who wants to help support the project can donate here. https://www.patreon.com/user?u=44228479 early testing of the esc and firmware..
and some reversing testing.
I would love to have this as a 4 in 1 ESC on my 3D quads. Amazing motor reversing performance.
Thank you, I'm using Dshot600 now and works well to me.
Could I work in the Configurator for Desktop and Android? Video The name is just an example. Is JavaFX (multiplatform) and easy to migrate to Android. I use MVC pattern. Not use FXML to the GUI, all is Java code (Gradle project). Is multilanguage, by the moment only English and Spanish. Best regards |
Hello,
I'm glad you like it. Serial comunnication with several baut rates is possible. The "complicated" thing here is wrap the C code to Java. We can use Swig or JNI for it. Yes, it be can open-source. For example Apache v2 if enough permissive and compatible with other Apache v2 projects (JavaFX, Android, etc) If you send me a email account I can add you to the repository and test it. Development tools are Eclipse and Java Development Kit. Regards |
Hello,
I added to you to the repository. I made a simple demo of the gauge for the motors, simple idea. Video I'm using JSerialComm library, are this the Modes of Operation availables. |
Nice! I like the graphic, that could be rpm feedback from the motor. I really don't know enough about serial coms to be of much help yet. Thanks for the repo, I will look into it. Can you get your esc configurator to work with a flight controller serial passthrough? I am not sure exactly how the serial is configured for that to work.
I have used the non-blocking mode with a FTDI chip and works fine. I have that works more in the connection view but works.
In the future is possible to use the event-driven callback mode in order to auto-connect but by the moment is enough. Yes the gauges are very cool and they can server to feedback yes, this app is a fork of other that I'm woking years ago for a FC but I'm going very slow, very much thing to do. Can you get your esc configurator to work with a flight controller serial passthrough? I am not sure exactly how the serial is configured for that to work. I think so. I'm not an expert either, but as soon as the view is over and the application can detect the available ports and can be selected, I'll do more tests with serial communication. |
Hello,
The serial communication is working. I read this from my rf meter with OpenESC, also I can connect with others devices. By the moment the process is automatic, is not necessary to set port and baut rate, but I have added a checkbox for change to manual mode. (not implemented yet). Code:
return: $-�3.9 dBm 000 uVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.7 dBm 103 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.6 dBm 104 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.6 dBm 104 mVpp$$-15.6 dBm 104 mVpp$$-15.6 dBm 104 mVpp$$-15.6 dBm 104 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.6 dBm 104 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.6 dBm 104 mVpp$$-15.6 dBm 104 mVpp$$-15.6 dBm 104 mVpp$$-15.8 dBm 102 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.7 dBm 103 mVpp$$-15.9 dBm 101 mVpp$$-15.8 dBm 102 mVpp$$-15.8 dBm 102 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.6 dBm 104 mVpp$$-15.7 dBm 103 mVpp$$-15.9 dBm 101 mVpp$$-15.8 dBm 102 mVpp$$-15.9 dBm 101 mVpp$$-15.8 dBm 102 mVpp$$-15.7 dBm 103 mVpp$$-16.0 dBm 100 mVpp$$-15.9 dBm 101 mVpp$$-15.4 dBm 107 mVpp$$-15.5 dBm 106 mVpp$$-15.6 dBm 104 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.5 dBm 106 mVpp$$-15.6 dBm 104 mVpp$ I have not the chip that you use, I use NXP, I'm going to write some code to try with a kinetis m0+ and the LPC Linker v2 in order to flash, read/write some code. Regards |
I've been following this as you post links in the Betaflight slack and when I remember to check on YouTube. I'm super keen to get this level of performance in a small 4 in 1 (around the size of the tinypepper (16*16 mounts, 20*20 board) or even the next size up (20*20 mounts 25*25 board).
I know that would take a LOT more work, but it seems you've got the design and code working a treat! I should just get the parts and build some up for a 5" rig with individual esc's on the arms or something. Though currently the time and motivation are lacking severely for projects. I'll keep watching intently, when work calms down a bit I might find some motivation! |
Time is the biggest problem for me. Every step is painfully slow for me and my rate of ideas vastly outstrips my rate of learning how to implement them. I am a full time farmer so winters are the only time I can do any real work on the ESC's.
The configurator that hexagonrc is working on is really a big step. I am going to work on serial interface on the esc side an hopefully we can connect the two. That really the last piece of the puzzle to make it more useful. Just the fact that a project like this exists keeps closed source devs on their toes and improves the tech for everyone. |
Thread Tools | |
Similar Threads | |||||
Whoops! | AGF rc 32 Bit ESC & super narrow ESC | Camille.Zhang | Product Announcements | 0 | Dec 29, 2017 01:32 AM |
New Product | Vgoodrc ARM 32-bit ESC | Vgoodrc | Multirotor Drone Electronics | 31 | Aug 21, 2016 10:03 AM |
New Product | Kiss 32 bit Flight Controller and ESC's | fpvdirect | FPV Equipment | 0 | Jul 04, 2016 06:27 PM |
Discussion | RTF 32 bit ARM ESC | akcom | Multirotor Drone Electronics | 5 | Feb 25, 2016 11:27 PM |
