This thread is privately moderated by UpNup, who may elect to delete unwanted replies.
May 27, 2019, 06:44 PM
Who are these that fly?
UpNup's Avatar
Mini-HowTo
Aileron and Flap p-51B
Amazing that it took several free hours this weekend just to make one flap and an aileron. Im trying to be careful, but wowzers. This is my second RC build from plans and no short kit this time. Gratification yes, instant no on this P-51B 57 WS.
Can I at least get a participation award? Ha!
May 27, 2019, 10:49 PM
If it flies, I can crash it.
rocketsled666's Avatar
Once you've done it a few times it gets a lot faster. I haven't stick-built in a while, but I built dozens of airplanes over the span of a few decades. When I started, the best glue was Ambroid and it took overnight to set. You'd pin everything together and go do something else while it dried. Then I got a magnet building board. No more pins. That sped stuff up quite a bit. But then CA showed up and then I was able to build about as fast as I could lay the parts down on the board... A model that'd take 2 weeks with Ambroid could be done in a (exhausting) day with CA.
May 28, 2019, 11:24 AM
UpNup's Avatar
Thanks for the encouragement. Yes, this build uses both Titebond II and CA. I use medium CA to give me a few more seconds grace. Is it me or does CA seem to be somewhat brittle? I like the Titebond's texture when dry.
Discussion Does 14" flaps with 18" ailerons sound about right? G.F. Beurling Electric Plane Talk 5 Oct 29, 2015 12:33 PM
Discussion HZ Sports Cub S ailerons now operating as flaps rickyg8438 Electric Plane Talk 18 Sep 28, 2015 01:17 PM
Help! ESM P-51 Mustang - What Control Rod Set Up Are You Using For The Flaps & Ailerons: electriceddie Fuel Warbirds 2 Feb 17, 2015 09:44 PM
My first PSS...a P-51B...question about aileron hinging roguewolf Slope 1 Apr 27, 2004 08:10 PM
