This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
May 27, 2019, 03:25 AM
2-Axis 30X EO/IR Gimbal For Fixed-wing VTOL
YANGDA 2-Axis 30X EO/IR Gimbal For Fixed-wing VTOL (7 min 31 sec)
Eagle Eye-30IE-U EO/IR thermal and 30X optical zoom visual imaging camera with 2-axis gyro-stabilized gimbal is specially designed to be used on fix wing plane and VTOL. The SONY 30X zoom camera provides 1080P 60FPS full HD video streaming and up to 360X zoom capability, which enable you to see every detail you need in the air even you are far away from the object. While the thermal camera allows you to detect targets in the night or low visibile conditions, and provides you with priceless information when you are carrying out missions like inspecting or monitoring objects. High-performance 2-axis gimbal is developed based on FOC(field-oriented control) technology, which will give you crystal clear video footage.
Compact and lightweight
The compact 1.2kg compact system is ideal for integration into UAV, fix wing and VTOL.
High-quality video sensor
Eagle Eye-30IE-U is using SONY FCB-EV7520 camera block, features anti-fog, video enhancement, and some other advanced features.
Auto object tracking
With onboard object tracking module, Eagle Eye-30IE-U is able to track static or moving target easily, keeping it in the center of the frame.
Continuous 360-degree rotation
The gimbal has continuous 360-degree rotation under standard HD-SDI output, which will enable the gimbal to track targets freely without any angle limit.
Geotagging function
Another feature for Eagle Eye-30IE-U is that the gimbal will geotag the video streaming and photos, also gimbal Yaw/Pitch angle, height, time information will be displayed on camera OSD, this is really important when you are conducting missions like rescue and search.
Easy for integration
Eagle Eye-30IE-U comes with an amazing advantage that the gimbal can not only be controlled via PWM signal, but also serial command. Also, gimbal status(like Yaw/Pitch/Roll angle, zoom position etc) can be obtained by sending serial command to the gimbal via its serial port, which is really useful for precise gimbal control and system integration.
Clean and simple wiring
Eagle Eye-30IE-U provides an outstanding wiring hub design for RC receiver and video output port, which makes wiring pretty easily. Also, the gimbal offers 2 smart speed modes: FAST speed and LOW speed. Fast speed mode is used for small zooming range, which makes the gimbal control sensitive and quick. LOW-speed mode is used for large zoom range, will enable you to target the object more accurately.
May 28, 2019, 02:57 PM
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F12 37
https://rover.ebay.com/rover/0/0/0?m...2F123779704901
New Product EAGLE EYE-30IE 30X EO/IR DUAL SENSOR 50mm LENS FOR THERMAL CAMERA charlesfang Multirotor Drone Talk 0 Jun 08, 2018 02:17 AM
Discussion 30X EO/IR drone zoom camera with object tracking and geotagging Gary Chen Multirotor Drone Talk 1 Oct 22, 2017 09:43 PM
