This thread is privately moderated by Merch, who may elect to delete unwanted replies.
May 26, 2019, 11:45 PM
Merch's Avatar
Mini-Review
Eachine E013 Plus Micro FPV Racing Drone With Racing Hoops And Timer
https://www.banggood.com/Eachine-E013-Plus-Micro-FPV-Racing-Drone-Anti-Turtle-Mode-w-5_8G-48CH-1000TVL-Camera-VR006-Goggles-p-1442886.html
RACING HOOPS
Eachine E013 Plus Micro FPV Racing Drone Anti-Turtle Mode w/ 5.8G 48CH 1000TVL Camera VR006 Goggles
Specifications:
Aircraft Brand Name Eachine
Item NO. E013 Plus
Size 104x115x43mm
Weight 48g
Color Red, White (Optional)
Material PP
Gyro 6-Axis
Remote Control 2.4G
Image Transmission 5.8G
Motor 8520 Brushed
Battery for Quadcopter 3.7V 500mAh 25C LiPo (Included)
Battery for Remote Control 3 * AAA battery (Not Included)
Charger USB/700mah
Flight Time 5mins
Control Distance 120m
Camera Lens 1000TVL M7
Frequency 5.8G
Frequency Point 48CH
Transmission Rate 0.01mW/25mW (The power rate could be switched to aviod the affection to other drones when flying.)
Sensor 1/3 "CMOS
View Angle 120°FOV 150°DFOV
Image Format NTSC
Frequency Control Press Once: Channel Switch
Press 1.5s: Band Switch
Press 3s: Change the power rate output.
- Band Switch: Press the B+ button once, it change to next band when you operate the transmitter.
- Channel Switch: After select one band, press the C+ botton once, it will change to next channel.The image come out shows the connection is ok.
VR006 Goggles (Optional) Size 138*129*79mm(without antenna)
Weight 164.7g
Display 3 inches
Resolution 500*300 pixels
Antenna Connector RP-SMA
Working Voltage 1S Battery (3.7-4.2v)
Working Current 350-450mA
Receiving Sensitivity -95dBM
Build-in Battery 500mAh 3.7V
Working Time 1h
Features
Small and Light, convenient to carry
With One Key Auto Search function.
Only English available.
Support OSD function, can display current power
Support AV-IN
Build in 3.7V 500mAh battery, 1h working time.
Features:
- 5.8G real time FPV image transmission with 1000TVL camera and VR006 goggles provides you real excellent flight experience.
- Bands and channels of 5.8G real time FPV can be change by transmitter directly.
- New Anti-Turtle mode allows you to turn the drone to upright by one key and takeoff normally when the drone crushed down and inverted to reverse side.
- Acro/Rate Mode.Control only by manual operation, you could fly airline what you want.
- 3 Flight Mode. Hover mode, Normal mode, Manual mode.
- One key take-off and landing can be achieved with the remote control,and novices can easily control it.
- FPV 25mw/0.01mw switchable. The power rate could be switched to aviod the affection to other drones when flying.
- Emergency stop remind, protect the drone from any protential damages.
- With low power protection overcurrent protection.
- Strong power system with 0820 brush motors 4-blade props.
Package Included:
1 x E013 Plus Quadcopter
1 x Remote Control
1 x Monitor Holder
1 x 3.7V 500mAh Lipo Battery (Battery Quantity Optional)
1 x USB Charger
4 x Spare Propeller
1 x Goggles (Optional)
1 x Straight pole antenna (Optional)
1 x Goggles Charging Cable (Optional)
2 x Cloth (Optional)
1 x Screwdriver
May 27, 2019, 05:53 PM
Merch's Avatar
Updated with pictures and the racing hoops with timer full video review will be up soon.
Jun 07, 2019, 06:33 PM
Merch's Avatar
Updated with Racing hoop video review.
New Product New Product - Eachine E013 Plus Micro FPV Racing Drone BGKevin Micro Multirotor Drones 62 Nov 30, 2019 02:33 PM
Video Eachine E013 Plus micro FPV RC Quadcopter with Eachine VR006 mini FPV Goggles (RTF) hermit81 Micro Multirotor Drones 0 Apr 26, 2019 05:51 AM
Discussion Eachine E013 Micro FPV Racing Quadcopter With 5.8G 1000TVL 40CH Camera VR006 VR-006 3 siriusflier Micro Multirotor Drones 9 Nov 28, 2017 11:06 PM
