Jun 21, 2019, 04:20 PM
Alfa Twin Spar's Avatar
Great! Motors are ready, it' s time to cut the flex shafts. I made a custom twin motor mount, distance between motor shafts is the same than prop shafts.
Dr Mad Thrust 2960 - 2200kv - 1600 watts
Jul 11, 2019, 12:24 AM
Here is the progress on the Twin Smash Shark, I have to adjust an glue copper tubes with teflons.
The COG is near the black dots on the top, where should you install the SeaKing ESCs?
I use different size of batteries, 2 x 4S (3300mAh each) in parallel and 1 x 4S (8000mAh), may be I will install the controllers next to the motors at the bottom of the hull, not on the sides.
Jul 11, 2019, 05:10 AM
Apache Kemosabi's Avatar
You say the COG is where the dots are so where were the esc,s when you worked out the cog , put them so she balances where she needs to be also dont forget to account for the hatch as cog will change drastically when you stick that on . Good luck finding a perfect cog running twins in that small hull its not going to be easy .
Jul 11, 2019, 01:38 PM
The COG at 30% is a very good start point.
With the stingers adjusted at 0 - neutral the position of the batteries is enough for a very good setup
Jul 12, 2019, 05:25 AM
I want to buy some propellers for the twin mono, what size do you suggest ?
The setup is not a RPM Monster, 4S and 2200kv, 32650 rpm unload.
Jul 12, 2019, 01:14 PM
RELAX. You'll live longer
785boats's Avatar
A pair of 440/3 blade props is where I would start If it were mine.
Jul 13, 2019, 09:12 AM
Thanks, do you know those propellers ?
https://fr.aliexpress.com/item/32860...3da26c37XArg2P
Jul 13, 2019, 09:23 AM
Hi Alfa,
I already bought this store (TILKIEA MODEL Store) very good, but propeller I prefer these here (TFL):
https://pt.aliexpress.com/item/32875...36877c83xb07FR
I already bought a lot in this store (HobbyWing Model Store) the seller is very cool, including always makes a discount on the price. They are all original TFL products.
Jul 13, 2019, 03:21 PM
785boats's Avatar
They are the same props .
TFL make them & sell them.
Tilkiea is a hobby store that sells a lot of TFL products, including the props.
They are good props I use them on some of my race boats.
Jul 15, 2019, 04:44 AM
Yes, TFL and Tilkiea propellers are the same, I received an order
Discussion Trim tabs, we're all trim tabs! patmat2350 Dock Talk 9 Jan 08, 2019 01:59 PM
Question Trim leaver/ tabs not working on T8RB smithdoor Radios 2 Dec 15, 2018 05:33 AM
Discussion JR X-388S aileron trim tab not working nkkromhof Radios 2 Mar 31, 2012 10:08 PM
Discussion Trim tabs or Turn fins? Darkcracker Racing Boats - Electric 9 May 03, 2009 05:45 PM
Discussion Tx trim tab not very co-operative Don McGill Hitec/Multiplex USA 1 Jul 19, 2008 04:37 PM
