This thread is privately moderated by DutchRC, who may elect to delete unwanted replies.
May 26, 2019, 10:03 AM
my RC. Your info
DutchRC's Avatar
iFlight iWing - Fiberglass composite FPV Wing
Halloa people
You might have come across this wing because iFlight have had several short video's about it allready..
An FPV wing, but not as you know them.. Is that fair to say? I think it is
Link to this airplane: iFlight 850mm Fiberglass iWing
So in this topic I'll post my findings eventhough it's not a review (I received a pre-production sample)..
Don't hesitate to post Your findings / etc on this wing!
iFlight iWing - Not just another Wing :) - SHOW & TELL (24 min 58 sec)
Specifications:
wingspan: 850 mm
length: ??
weight: 1 - 1.3Kg All Up Weight
material: Balsa composite
kit type: PNF
motor: Xing 2208 2150 Kv
propellor: 7x4.2
ESC: 60A
servo's: 2x Digital MG AGF B13 3.8Kg
receiver: 4 channel, or SBus if you want to ad a Flight Controller
lipo: 1800 - 3300mah 4S (not included)
ailerons: 2x elevon offcourse
rudder: nope
flaps: nope
retracts: nope
lights: yes
stabeliser: nope
May 29, 2019, 04:53 AM
The looks of this Wing are pretty good! Nice review!
Jun 02, 2019, 07:07 PM
my RC. Your info
DutchRC's Avatar
Thanks Eric
I did do a dive into the deep end (a iNav setup) which I knew I would regret :P
But ohw well.. nothing ventured, nothing gained...
Jun 03, 2019, 11:15 AM
It seems this iNav is recommended as flash software for the flightcontroller you gave me. It has to do with getting the FC up and running for a fixed wing aircraft (or so). Is there an alternative?
PS meanwhile I received the Eagle Tree and, even for me :-), it was a breeze to set it up. I haven't tested it yet, but the pre-test results look promising.
Jun 03, 2019, 11:24 AM
my RC. Your info
DutchRC's Avatar
that flight controller can be used in 2 scenario:
+ multirotor.. easy to set up with for instance Betaflight.
+ airplane.. yep.. that would be iNav.. it IS possible to use Betaflight but not really recommended..
setting up iNav is NOT a breeze.. but you can't compare it to an Eagle Tree.. that would be like comparing a motorcycle to a bicycle.. the Eagle Tree is not much more then a simple gyro / stabi and consequently easy to set up..
my RC. Your info
DutchRC's Avatar
ALLSO!
3D Gyro AND Crash Testing! (see sidebar) (8 min 29 sec)
New Product iFlight FPV Flying WING W850 850mm Wingspans Glass Fiber Composite FPV RC Airplane PN Merch Banggood.com 1 May 01, 2019 09:30 AM
New Product iFlight Ultimate iX5 Moulding Composite Material FPV Frame Kit D Gains Mini Multirotor Drones 1 Aug 14, 2017 02:27 AM
composite hollow fiberglass wing vs. fiberglass over foam wing? ChrisFeole Power Systems 7 May 21, 2001 02:33 AM
