May 25, 2019, 04:16 AM
RCvertt's Avatar
Arduino not reading Spektrum 4648 receiver.
Has anyone connected an Arduino up to a Spektrum 4648 DSMX Serial Receiver with Diversity? I know it's been done with the old spectrum sat receivers but can't find any info on the protocol used by these new receivers.
I don't need to read any telemetry just the rc signals from channel 1 to 6.
I'm using the YMFC32 projects receiver code at the moment and it doesn't appear to read the receiver. It works with a PPM encoder connected to my Futaba channel order receiver, but doesn't work with the spectrum receiver.
Attached is the YMFC32 set up program that can read a Futaba PPM receiver that has only one signal pin wire. It reads all zeros if I connect up the Spektrum receiver. Basically I would like to put a Flip32 FC into my Horizon Hobby V22 but still use the Spektrum 4648 receiver that came with it.
May 25, 2019, 04:42 AM
Spektrum sat rx use no PPM but have a serial output, afaik.
Don't ask me about baudrate and the data coming out there, but i've seen UART pins connected to it.
May 25, 2019, 01:13 PM
RCvertt's Avatar
I see. The YMFC32 doesn't support UART so it sounds like I'm stuck. I was hoping it would be a simple channel order thing so I could keep my Spektrum gear but it sounds like I'll have to sell it off after all. Thanks for the info.
May 25, 2019, 03:21 PM
RCvertt's Avatar
I'd settle for a serial to PPM encoder if one exists? A DIY one would be even nicer.
///Edit- Just found that I have a 617Xl satellite receiver that outputs CPPM. Will edit this page if it works.
Help! Spektrum DX 6 to SPM 4648 receiver binding Conlanmike Beginner Multirotor Drones 1 Mar 28, 2018 02:25 PM
Discussion Dys f4 pro v2 and Spektrum SPM 4648 Motomac Scratchbuilt Multirotor Drones 7 Aug 21, 2017 04:41 AM
Discussion Spektrum AR8000 + Arduino + read RSSI oshyshko Radios 7 Jul 02, 2017 04:17 AM
Help! Vortex 250 Pro and Spektrum SPM 4648 Receiver rsghowellnj Beginner Multirotor Drones 3 May 17, 2016 03:30 PM
Alert From what i am reading, it is not as bad as it seems, however....please read on... jhastings Model Aircraft & Drone Advocacy 2 Jan 06, 2016 11:59 AM
