May 24, 2019, 08:15 PM
Need more speed!
Chuppster's Avatar
Help!
Leaky Valves - Need more compression!
I have a friend that just bought a second had Saito Fat Head 120, and it has very little compression. When we first got it the valves were stuck. We pulled the head off and removed the intake valve (the more stuck one) and gently cleaned it up with a plastic scratch pad. Now both valves move freely but they do not seal. Is there a way to get them to seal again?
May 24, 2019, 08:24 PM
Systems Test Engineer Amateur
Gary Cee's Avatar
Set the valves, run the engine.
After a few tanks you can re-evaluate.
Then check for leakage points and sources.
May 24, 2019, 09:01 PM
Need more speed!
Chuppster's Avatar
How can I run the engine if there is almost no compression?
May 25, 2019, 05:57 AM
I TOBOR's Avatar
Chupp, a trick that sometimes works, push the valves open about 1/16" with your finger nail and then let it snap shut, amazing what that will do for leaky valve. If it works you'll need to readjust them.
May 25, 2019, 06:13 AM
Gary Cee's Avatar
Like I TOBOR said, and perhaps add some oil or fuel around the valves. Push on the stems only . If you push on the edge of the spring or retainer you run a risk of losing a valve keeper.
Still, they often start without all that by just the starting operation. A bit balky perhaps but the fuel priming wets the engine and flipping the prop will often free up the valves.
May 25, 2019, 09:38 PM
kimchiyuk's Avatar
Doesn't need much compression to run; much less than you'd think! Sometimes after rebuilding an engine one or both of the valves will sound like they are leaking. You won't have that nice snappy compression we always look for. Once they run a bit, the compression comes right back.
May 26, 2019, 06:20 AM
Need more speed!
Chuppster's Avatar
We ran it yesterday an I was surprised that it fired! We tinkered with it but I have yet to get it to idle. It appears that the exhaust valve is still not seating properly, so I guess we will give it a tank at full throttle and see how that goes.
May 26, 2019, 07:37 AM
Gary Cee's Avatar
Check the rocker clearance . It may have closed up and could prevent the valve from fully seating.
May 26, 2019, 07:47 AM
Club Saito | Genesis 8:11
Bunnyshooter223's Avatar
Valve Leakage, me too
Same issue here, but intake valve seal on an FA-50.
New valves, it's the head side. A new glow plug seemed to help a lot, but it would not idle low without dying. Difficult to start when warm. Compression feels low, comes up a bit when primed but low overall. Sometimes erratic power at mid-throttle
The head on mine is 'kinda rare' too as it is a 'newer FA-56 style'
Edit: mine had original valves strike piston, don't know why. I just wanted to share my symptoms because it seemed to run well enough, at first, that i posted it for sale. But i quickly pulled it after testing it more
May 26, 2019, 08:07 AM
Cougar429's Avatar
From your description it sounds like things were stuck from long term storage.
Did you remove the exhaust valve completely to clean? That would have allowed you to also see if damage to the valve or seat surfaces.
Are the seats plated or bronze?
How was the compression once the engine was hot?
May 26, 2019, 09:16 AM
Gary Cee's Avatar
The compression was originally nil but came up after the initial running. That is why the valve lash should be re-checked. If the compression improved there is an excellent chance that the valve lash closed up.
No plated seats.
May 26, 2019, 11:50 PM
Diesel Danny
danny mz's Avatar
It might be worthwhile checking the rings too.
I have encountered a few old engines where the rings were stuck in the grooves with resulting low compression.
* Danny M *
Discussion Leaky boat Buggy285 Dock Talk 21 Aug 30, 2016 10:41 AM
Help! Cox teedee .020 leaky tank. MiZer1981 1/2A Planes 30 Jun 08, 2016 09:17 AM
Discussion Leaky stuffing box james.wood Scale Boats 10 Apr 21, 2016 01:05 PM
Help! Saito 150 intake valve guide - suggestions needed! SRQFlyer Engines 0 Sep 13, 2015 01:08 PM
Discussion Saito 56 valve timings for intake and exhaust valves needed Tyro Major Engines 20 Sep 09, 2014 07:05 AM
