May 24, 2019, 03:01 PM
Painting preperation on a ARC
OK guys and ladies I have a Focus Sport pattern plane that I plan on painting rather than using a film covering. I plan on using Wings West Products. 3/4 oz cloth laid down with epoxy, primer, and sanded to a "baby bottom" finish and paint and sealer from Wings. My question, should I glass cloth the wing, stab, rudder and fuselage prior to starting the assembly of the plane and then do the primer, sanding and final painting? I painted planes back in the 70's but most had fiber glass fuses and I can remember the sequence. I guess it's something about getting old!
I want to use paint so I can tape and paint the three color scheme that I want.
Bill
May 27, 2019, 05:11 AM
Everybody does it differently but I like to fiberglass and prime the control surfaces before I paint. After everything has been primed and sanded, I then glue the control surfaces to the hinges and paint the plane as an assembly.
carl
Jun 03, 2019, 10:43 PM
oysifly's Avatar
I use .56oz cloth and do all the fiberglass at the same time. I then prime the fuse, wing and all control surfaces separately. I paint my control surfaces separately from the plane but I install them and clear it all at once. This picture is before 2 stage clear and it's also Wings West paint. I'm really looking forward to my Phoenix 8 build and painting it.
Discussion sealing balsa wood in preperation for covering ? the_gr8t_waldo Balsa Builders 6 Jan 28, 2018 11:38 AM
Discussion ARC recommendation for the FAA on Drone's Kamer FPV Talk 0 Apr 11, 2016 03:13 AM
Help! Hull Preperation edmigley51146 Scale Boats 0 Jun 17, 2008 08:09 AM
Discussion Cessna 177 (ARC - ABS) painting siddus Fuel Plane Talk 1 Jul 30, 2007 08:29 PM
Making and preperation of a new Lipoly pack **neons** Batteries and Chargers 7 Apr 01, 2004 03:53 AM
