May 23, 2019, 09:07 AM
PalouseFlyer's Avatar
Help!
XK K110 - have to almost give it full throttle to hover
Well, I am still trying to understand why my K110 is become so sluggish in the air.
I recently replaced the main gear and have it pressed all the way up snug to the bearing. These are brand new packs I am using, so I know it isn't the battery. I am not trying to do any 3D at all just simple pattern flying, but I practically have to give it full throttle to keep it in a hover.
Thanks for any help!
May 23, 2019, 11:24 AM
Hi,
Standard plastic swashplates are designed to be easily disassembled up and down during a crash. Conversely, the upper and lower assemblies are incomplete, and in particular if the plug is inserted too much, the amount of collective pitch operation is insufficient and the main rotor pitch is not sufficient. Therefore, even if the rotation is increased, the buoyancy may not be obtained. In this case, you can correct it by correcting over-insertion or raising the pitch curve.
Mini-Review XK K110 3G/6G Small CP Heli thread - same or better than V977? (Work in Progress) SoloProFan Micro Helis 6597 Nov 11, 2019 03:39 AM
Discussion Any body have this prroblem on their xk k110? rayfan Micro Helis 11 Jan 15, 2019 11:53 PM
Discussion Hovering, cutting power, then full throttle before crashing Ruskils Multirotor Drone Talk 0 Jan 06, 2019 02:37 AM
Discussion Fitting the metal head from the XK K120 to the XK K110 issues DavidDavidson Micro Helis 4 Dec 27, 2018 12:41 AM
Question Xk k110 - hover debugging elias.rocha Micro Helis 5 Sep 13, 2018 09:00 AM
