This thread is privately moderated by Bella Liu, who may elect to delete unwanted replies.
May 22, 2019, 10:09 PM
Cool
SJ RG01 5.8G 48CH Dual-Displays Diversity FPV Goggles w/ 3.7V 1500mAh Battery DVR
Frequencies and Bands:
This product is equipped with dual displays with a resolution of 960 x 240.
Adjustable sight distance is ensured. It is compatible with 5.8GHz band that is popular on the market.
The diversity receiver module enables stable image quality.
The real-time video recording using a trans-flash (TF) card allows you to share your happiness with your friends.
With an attractive appearance, the product is compact and light in weight, which is designed based on the facial structure to ensure comfortable wearing experience.
New version upgrades with USB,you can charge it with power bank directly now (from 11.07)
Specification:
Input power: DC 6-28V, DC12V/380 mA, maximum charge current: 300 mA
Display resolution (dual display): 960 x 240
AV output terminal: Ф3.5mm, video output impedance: 75 ?, audio output impedance: 10 k?
DC socket for input power: diameter: 6mm, inner pin diameter: 2.1mm
Class of the TF card: class 10, maximum size of the TF card: 32 Gb
Micro USB interfaces allow convenient file saving
Optional battery: 3.7V/1500 mAh, 80mm x 19mm x 7mm (L x W x H)
Adjustable sight distance: min. value: 58mm, max. value: 63mm
Product size: 175mm x 102mm x 68mm (L x W x H)
FOV: 40 Degree
Total weight: 278g
Features:
Dual display with a resolution of 960x240
Adjustable interpupillary distance(58-63mm)
Double receiver modules ensure stable image quality
Compatible with universal 5.8GHz band emitter
Supports real-time video recording using 32G TF card
Attractive appearance,comfortable wearing experience
Package included:
1 x SJ-RG01 Goggles
2 x Antenna
1 x Power cable
1 x AV cord
1 x Battery (1,500mAh)
1 x User’s manual
New Product URUAV 5.8GHz 48CH 4.3 Inch Display FPV Goggles Auto-Searching Built-in 3.7V 1000mAh Merch Banggood.com 0 May 21, 2019 06:53 AM
New Product Skyzone SKY02X SE Version 5.8G 48CH True Diversity FPV Goggles Built-in Fan DVR Suppo scousethief Geekbuying.com 0 May 06, 2019 06:46 AM
New Product TOPSKY Prime1S 5.8G 48CH 2.4 Inch FPV Goggles Diversity Receiver Built-In Battery DVR alex_nikiforov FPV Equipment 2 Oct 22, 2018 08:29 AM
New Product SJ RG01 5.8G 48CH Dual-Displays Diversity DVR, 74€ 527FPV FPV Equipment 4 Apr 03, 2018 11:01 PM
New Product SJ RJ01 5.8G 48CH Dual-Displays Diversity FPV Video Goggles w/ 3.7V 1500mAh Battery D smg24 Banggood.com 0 Jan 04, 2018 05:24 AM
