May 22, 2019, 09:22 PM
Help!
Three wire (ESC to Motor) gang connector?
I am looking for a three wire (gang) connector system for the ESC to Motor wires; 11 volts up to 14 amps.
The only type I have seen won't fit my installation, the Amass XT units with the connectors arrayed around the center. These are too big to fit.
I need something with the three wires side by side. Aircraft is a twin, and connections must be made when attaching the wing, 6 separate wires to connect if I can't find a suitable three wire gang connector. Must be lots of twins out there flying with a similar situation - maybe someone has a good DIY system. Thanks.
May 22, 2019, 09:42 PM
pilotpete2's Avatar
https://alofthobbies.com/mr30-three-conductor-plug.html
This may be what you're looking for
Pete
May 22, 2019, 10:03 PM
Perfect. Thank you.
Question Two wire motor - Three wire ESC Lt_Dan Parkflyers 31 Mar 04, 2021 05:07 AM
Question Tap Voltage Sensor Wire Into ESC Battery Wire w/o Removing Connector aymodeler Radios 4 Jul 29, 2018 04:33 PM
Question can I shorten the three wires from the esc to the motor? grfcon Power Systems 7 Jun 17, 2010 11:33 AM
Discussion ESC with two wires - motor with three wires ? SpookiePower Power Systems 4 Apr 14, 2010 11:35 AM
Discussion Soldering "bullet" connectors to ESC/motor wires Tony_Fletcher Power Systems 12 Feb 26, 2009 10:50 AM
