This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
May 22, 2019, 06:04 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
Sonicmodell Binary Long Range FPV 1200mm Wingspan $97.99
https://bit.ly/2VTwYrR
SonicModell - Binary: Official intro (5 min 35 sec)
SonicModell - Binary: DUSK Lighting System preview (1 min 46 sec)
Link to PDF MANUAL
Highlights
Powerful twin-motor configuration, specially designed for long range FPV with huge payload capabilities.
Carefully considered a detachable system for the main wing, easy to assemble in just a few minutes.
Removable motor and ESC hatch for easy maintenance and part replacement.
Ailerons, flaps, and elevator with built-in carbon fiber rods for extra reinforcement.
Multi-camera nose mounts to accommodate virtually ANY FPV / HD camera in the market.
Extra flexible belly mapping camera bay, with great DIY possibilities. Ideal for the survey and dual-camera setups.
Tons of room inside the fuselage for more FPV gear and bigger batteries, reinforced by carbon fiber strips along the fuselage.
Clean and clever internal design will let you decide exactly where you want to place your gear for minimum interference.
Modular designed landing gear, easy to attach and detach, makes takeoff and landings much easier.
CG bumps under the main wing.
Optional DUSK lighting system, with 3-position PMW control: OFF / NAV lights / NAV lights + Landing lights.
High-impact plastic protection in case you donít want to use a landing gear.
Detachable clear front canopy for better aerodynamics.
Fully functional pre-molded flaps.
New Product SonicModell Binary 1200mm EPO Twin Motor Multirole FPV Platform (Official) SonicModell FPV Aircraft 238 Today 07:39 PM
New Product Free Testing - Sonicmodell Binary 1200mm Wingspan EPO Twin Motor FPV RC Airplane KIT BGKevin FPV Aircraft 39 Jun 12, 2019 07:08 AM
New Product Sonicmodell Binary 1200mm Wingspan EPO Twin Motor Multirole Aerial Survey FPV Platfor scousethief FPV Aircraft 0 May 14, 2019 04:19 AM
Discussion Sonicmodell Binary 1200mm Wingspan EPO Twin Motor scousethief Banggood.com 0 May 14, 2019 04:17 AM
New Product Sonicmodell Binary 1200mm Wingspan EPO Twin Motor Multirole Aerial Survey FPV Merch Banggood.com 0 May 07, 2019 05:26 AM
