May 21, 2019, 09:15 PM
thermal switch mode relinquish to slider
I'm flying ALES/F5J style e-glider & wondering how I would go about accomplishing an additional feature. Right now I have 3-position Se switch set up as forward=speed, middle=normal, back=thermal. In thermal mode I just have fixed % positions for flaps down, aileron down & elevator compensation, with a bit of delay
What I'd like to accomplish is: when I select this same thermal position (only), it relinquishes control to right side slider where I can vary the same surfaces (aileron, flaps, elevator) from zero to some maximum. As opposed to what is now essentially an on/off mixture setting. In any other switch mode I would like slider deactivated. Is this a logic application? Better yet, does anyone have a similar procedure I can adapt? The model is 2 aileron + 2 flap wing type.
Dec 11, 2019, 03:14 PM
F3B
satinet's Avatar
Just use dual rates. Zero rates in the flight modes you don't want travel.
But if you are using free mixes master value to zero in speed and normal.
Or use a function curve and make it flight mode specific.
It's easy to do. I've got this on a few gliders. Always remember nearly all settings on the radio can be flight mode specific. So however you acconplish it just make the setting zero where you don't want it.
Discussion ARM mode & another mode on same switch MoyRC Multirotor Drone Electronics 4 Oct 01, 2016 07:42 PM
Help! Assigning Butterly to R or L Slider instead of switch Luckyducky Hitec/Multiplex USA 3 Jan 25, 2016 08:07 PM
Mini-HowTo RadioLink AT9 Pix Hawk Mode switch setup APM AT9 mode switch how to S bus aopen3434 Multirotor Drone Talk 1 Aug 11, 2015 03:11 AM
Discussion tg9x replace switch with a 3 pnt switch or slider? nilshv Radios 0 Aug 05, 2014 02:46 PM
Question Switch between flight modes while thermaling? isobar Hand Launch 74 Jul 06, 2011 04:28 AM
