May 19, 2019, 10:43 AM
Joe Nall 1/3 Scale Pilatus Porter
Does anyone have any video of the 1/3 Scale Pilatus Porter in flight? If you do, I would appreciate you posting it here!
Jeremy
May 20, 2019, 09:35 PM
Only thing that could have made it cooler was if it was a real turbine.
May 21, 2019, 10:33 AM
The reason it was not set up with a Turbine is that I will be using this aircraft for Aerotowing, and the turbine would have very limited tow time capability! I know as I have the smaller brother 3.2m with an SPT5 and only get 4 to 5 tows dependent on glider size, weight and drag! Not to mention the SPT15 is over$7000! Plus the fact that we made a drive shaft system so the inverted DA200 would not poke out it's cylinder heads in the narrow nose, which would have been very non Porter Like
Jeremy
May 22, 2019, 02:54 PM
I would like to know more details on this model including specifications and detailed pictures.
Discussion 1/3 Scale Pilatus Porter swiss1 Joe Nall 2019 0 May 19, 2019 10:33 AM
Build Log Joe Nall 2017 Community Build: Joe Nall Goes Full Scale R/C sml Joe Nall 2017 33 May 30, 2018 02:07 PM
Contest Scale Build-Off 3 "Pilatus Porter PC6 (1/8.5 scale)" czirh Scale Kit/Scratch Built 15 May 31, 2014 01:48 AM
Question Pilatus Porter (1/8 scale) - Airborne Plan Calando Scale Kit/Scratch Built 2 Oct 03, 2006 10:04 PM
