This thread is privately moderated by kallend, who may elect to delete unwanted replies.
May 18, 2019, 01:02 PM
Flying R/C since 1964
kallend's Avatar
Make your own EDF afterburner
Make Your Own Inexpensive Centerburner
I have a dozen or so EDF models, most of which are of types that were/are equipped with afterburners. After buying several LED “centerburner” systems, I decided to see how hard it would be to make my own.
THIS IS NOT A KIT AND I'M NOT TRYING TO SELL YOU ANYTHING.
So this is what I managed to do:
aftrbrnr Su25 (0 min 22 sec)
This project requires electronic soldering and component wiring skills and is not a good first electronic project. However, anyone with some experience will have no problem.
It also requires access to a 3D printer to make the adapter to mount the lamp to the EDF motor. I have posted some adapter STL files for many popular systems on Thingiverse.com and there are services listed there that will print parts for you if you don’t have your own printer or a friend with one. Even a cheap consumer grade 3D printer will suffice as the adapters are neither large nor complex.
https://www.thingiverse.com/thing:4042564 .
If you want to design your own, there is simple design software available (such as the FREE https://www.tinkercad.com ).
This article only describes the electronic part; fabricating the adapter to mount the LED unit to the EDF motor is not covered. Anyone familiar with 3D printers should have no trouble making the mount, it takes about an hour to print on a typical consumer grade printer. While the adapter is printing you can be installing the controller and wires.
Total cost of the electronic components for the system is less than $14.
EDIT: Parts costs have gone up a bit since I wrote that on account of tight supply during the pandemic. Still under $20 for a single
Two different controllers are described: one is a ready made and readily available brushed ESC which can be used with almost no modification. The other is an Arduino based controller which requires about an hour of work to assemble, but which provides a realistic "flickering" effect to the afterburner.
First, I found a suitable high output amber bulb that has it’s own inbuilt voltage regulator. These use the exact same LEDs as the (expensive) commercially available afterburner systems.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It has a low cross-sectional area and provides minimal obstruction to the airflow.
EDIT: I am no longer recommending the above bulb except for the Arrows Mig 29
An alternative, cheaper bulb (less than $2 if you buy a 10-pack) is at:
Not only is it cheaper, it is a bit brighter, and easier to remove the plastic base. It is, however, a bit bulkier.
It requires a slight modification to the adapters listed later in the thread.
These are very bright, and run on anything from 9 – 30 volts. Its current consumption when full on is only 300mA, and the four brightest LEDs are behind a lens that directs their light along the bulb axis. With a little fiddling assisted by a razor saw I was able to remove the yellow plastic bulb base and expose the inbuilt regulator and its connections.
The Ready Made Controller
To control it without making a custom controller I found a 10 Amp ESC for BRUSHED motors. $14 for two from Amazon:
EDIT: later in this thread I describe a custom Arduino based controller which has some improved features (Flickering, and independent control of two lamps), but takes a bit more effort to implement.
Link: https://www.rcgroups.com/forums/show...3&postcount=82
The following section describes the brushed ESC controller:
There are other sources with various prices, but they all seem to be identical. They were originally made for R/C trucks. Various brands seem to come in and out of stock but there always seems to be something available.
It has a built in BEC too, which we definitely do NOT want since it is not up to the job of powering an EDF with retracts, servos, etc. The spec sheet shows a voltage limit of 9V when using the BEC, but it easily handles a fully charged 4S LiPo when the BEC is disabled. The ESC current drawn is only 300mA rather than 10A that the controller is rated for. To disable the BEC simply cut the red wire in the “servo” lead that goes to the receiver. THIS IS IMPORTANT! The black (ground) and white (signal) wires should remain intact, and the ESC will be powered by the red and black power input wires from the red JST connector. There is an on/off switch on the ESC. You can leave it in place or simply cut it off and connected the wires together so the ESC is permanently enabled.
I decided to limit the voltage input to the controller to 4S LiPo voltage, so on a 6S (or more) system I’d take the input from the balance connector tap at the 4S position (nominally 14.8V but higher when fully charged). This is plenty to power the LEDs to maximum brightness. I ran the setup for 2 hours continuously with no ill effects to the ESC – it didn’t even get warm to the touch.
The ESC was designed for surface vehicles and has “forward” and “reverse” output, with "off" when the stick is in the middle. The LED unit is insensitive to its input voltage polarity and will illuminate either way. If we just connect the ESC control lead to the throttle channel output with a Y connector, the LED will be full on at both zero throttle and full throttle. To prevent the LEDs coming on at low throttle I inserted a diode in the red lead from the ESC to the bulb (you can use either red or black lead, I used the red one for no particular reason). This blocks the current flow when the ESC output is “reverse”. Given that JR/Spektrum and Futaba use opposite throttle signal conventions (and I don’t know about Frsky, Taranis, Jeti, etc,) you will have to determine by trial and error which way around to connect the diode. You can’t damage anything by getting it wrong, you'll just light the LEDs at the wrong end of the throttle stick movement. Pretty much any diode with a current rating of 1A or more will work, even a dirt-cheap 1N4001 (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). I used a Schottky diode (15 for $9 from Amazon) because it has a lower voltage drop, but this is really unnecessary).
With the system connected up as described, the centerburner is off when the throttle is below 50%, and progressively lights up as the throttle is advanced beyond this.
You will need to make a suitable mount to attach the LED unit to the rear of your EDF motor. I 3D printed one, basically an ogival shape tapering down to the LED unit diameter. The details of the mount will depend on both the size and the type of the EDF motor (inrunner or outrunner). You will need to leave a hole for the EDF power leads to exit, and possibly some cooling holes too depending on your motor. Be sure to attach the mount securely to the EDF. The LED bulb can be held in place in the mount with C/A or epoxy. Be sure to secure all wires so they can’t get entangled with the fan. I have posted a bunch of 3D .STL files on Thingiverse for various EDF units (link is at the top of this post).
The Flickering Controller
Here is a link to the flickering controller:
This requires some soldering to complete, but can be made in about an hour.
EDIT: Suko has created some more detailed step by step instructions and posted them here:
https://www.rcgroups.com/forums/show...p-Instructions
May 21, 2019, 02:38 AM
edwen303's Avatar
Thanks Kallend sharing this trick! Just tried and it worked with a 3s brushless power system.
I tried but failed before using Y-connection between brushed ESC and brushless(power) ESC for my light, the key is what you described "to disable the BEC in brushed ESC". Will try again on 6s EDF system tomorrow. So far I use 3s to power brushed ESC. The 70mm LED ring is from banggood.
https://usa.banggood.com/70MM-COB-LE...r_warehouse=CN
Also from amazon: https://www.amazon.com/GrandviewTM-6...39127010&psc=1
Actually it is not necessary to cut the red wire to connector, just lift up the plastic stopper with tiny pointy tool like tip of Xacto hobby knife, and pull out the red wire on the servo connector.
May 21, 2019, 07:46 AM
kallend's Avatar
Originally Posted by icarus the 2nd
Why did I stop using it ? Compared to the rcgeeks's centerburner or some other afterburner controllers (Xicoy comes to mind) it didn't have a flickering effect which for me is 75% of the afterburner effect ... the brused ESC method only changes the led's intensity.
Flicker is easy if you have a spare channel and a Tx with a sequencer. Create flicker with the sequencer, mix with throttle, and use that channel to drive the afterburner controller.
EDITED TO ADD: A DIY flickering controller is described later in this thread.
May 21, 2019, 09:50 AM
edwen303's Avatar
Originally Posted by kallend
I haven't compared with rcgeeks, but I doubt he uses any different LEDs than I do. I have compared with two other versions that are on sale and its the same as one of them and brighter than the other.
The LED bulb I used is for the turn indicator on a car. It's plenty bright enough to be seen in broad daylight. That's why I chose it.
RCGeek's system uses yellow LED bulbs that shine backward like flashlight, running ~7 V. I posted the amp and wattage number on his RCG thread somewhere. Gooniac also has his own system.
It is great we can make our own system for a fraction of the price, for an inrunner or outrunner with tailcone like FMS 1900kv 90mm system. Great summer project.
May 22, 2019, 10:01 AM
bettsmums's Avatar
Home Made centerburner
Here is what I made for my Freewing 90mm F4 Phantom. I only sanded the side of the LED light so that it is basically complete. I had a GWS brushed speed control that was forward only so I didn't see any need to take the LED light apart because no diode was needed. I also thought that using the original streamlined fairing would be better because the aluminum might act as a heat sink. Mine also flickered just a little bit when it first starts lighting up before it hits full throttle. Do you think I am on the right track?
May 22, 2019, 01:13 PM
EDF Balance GURU and RC addict
gooniac33's Avatar
The GWS esc are worth their weight in gold!! I first got a hold of those about 10 years ago and they are awesome for this sort of thing! I used that on my 50mm L-39 back in the days and it worked awesome on up to 4s voltage. I use them as switches in several of my planes to date. But can not find them anymore... I just use the simple 2 amp ones with really good results. Just wish that they still made them!!
Also your method is very similar to mine. Mine is even simpler though! You would be surprised at how bright it is too!
May 23, 2019, 04:29 PM
kallend's Avatar
Originally Posted by edwen303
What I noticed so far is that brushed ESC for airplane will light up the LED once throttle up, even just barely throttled up. Any way to light the LED after half throttle with airplane brushed ESC?
Just ordered some LED and car brushed ESC, thanks Kallend!
Yes, use brushed ESC for car, tank or boat that has zero output at mid stick, and add the diode as described to block it when in reverse. Then the light doesn't come on until throttle > 50%
Latest blog entry: Make your own EDF afterburner
May 23, 2019, 04:31 PM
kallend's Avatar
I used a 1N4001 diode in my F-35. Works just as well as the Schottky, and I got 250 of them for $5 from Amazon. That should keep me in diodes for the rest of my life.
May 25, 2019, 12:38 PM
bettsmums's Avatar
Test flight with full after burner
I got my first flight with my home made center burner. Mine is using a HobbyKing RC electronic switch to turn the burner off and on. The burner is using the full 6 cell voltage. The brightness was the same with only 11 volts but 24 volts is more convenient. I will post the 3D printed part on Thingiverse later today. It is mounted on the 6 cell stock 90mm out-runner Freewing fan in my F4 Phantom II. I drilled four holes in the stock fairing to assist with motor cooling. The 3D part is a tight fit in the original opening and the LED bulb is glued in with Zap Goo. The only modification to the LED bulb was to sand the sides of the bulb mount to reduce the width to the same as the round part of the bulb. The jet exhaust were lined with A/C metal duct tape with the peel and stick backing from the fan unit to the tail cones. Thanks to Kallend for the great ideas to get me started.
May 25, 2019, 01:49 PM
Fly as high as the sun
icarus the 2nd's Avatar
Looking very good!!
May 26, 2019, 03:00 AM
edwen303's Avatar
More LED options:
Got some of these a while back. Now tested with brushed esc seems brighter than car turning light LED: https://www.banggood.com/Multicolor-...r_warehouse=CN
These LED chips are pretty close to the stated 10W and got pretty hot after brief running at <12 V, but shouldn't be an issue as it will be mounted with airflow from the fan. It is polarized but easy to solder. Tested and worked great. But so far I have only white light LED installed in Freewing Mig 21 (inrunner). Will see how it shows tomorrow during daylight.
Also from Amazon, seems very bright, a little cheaper and almost as bright as Kallend's original pick:
The amp and wattage reading from this is lower than Kallend's pick, but feels brighter.
Jun 22, 2019, 12:32 PM
kallend's Avatar
Put one in my new FMS F/A-18
I think the key to getting a good result in a bifurcated exhaust with a single fan is strategic placement of refecting surfaces in the duct - much cheaper than using a second LED cluster.
Jul 22, 2019, 03:34 PM
kallend's Avatar
Having written that, I decided use a spare bulb anyway in the F/A-18, with one directed down each tailpipe. Should be plenty bright! Will fly it tomorrow.
Aug 05, 2019, 04:17 PM
kallend's Avatar
Here is the F/A-18 with the twin burners, taking off in bright sunlight.
(It's easy to look good after sunset or indoors looking straight down the tailpipe; the test is how does it look at midday in the Sun, from the side.)
Aug 08, 2019, 02:12 PM
kallend's Avatar
Did you notice the change in thrust after installing this bifurated corn lights?
No. Measured static thrust is 1.9kg with the stock FMS inrunner. That's MORE than the same fan gives in my FW F-16 and the same as i get in my F-104
The lamps themselves are well aligned with the tailpipes so they really aren't blocking the airflow.
Discussion Make an EDF suggestion! Barry Leger Electric Ducted Fan Jet Talk 25 Jan 28, 2017 12:22 AM
Discussion What to make with spare parts from an EDF L-39? RedheadRedneck Crash Discussion 0 Jun 08, 2016 08:55 AM
Discussion New to EDF's Trying to make an EDF Trainer scote621 Scratchbuilt EDFs 12 Oct 15, 2011 06:03 PM
How do I make an EDF-50 DD run in reverse without burning brushes? birdofprey Power Systems 3 Dec 24, 2002 02:55 AM
someone needs to make an EDF X-43, come on! Try it! e-sailpilot86 Electric Ducted Fan Jet Talk 2 Jul 29, 2001 10:26 PM
