May 18, 2019, 09:05 AM
airspeed sensor, pololu, Teensy 3.2 I2C daisy chain
I'm adding airspeed to my homegrown (working) Teensy flight recorder. This thing has worked fine for a couple of years recording to a microSD, time, gps position, mag heading, gps-altitude, barometric height, horizontal accuracy, vertical accuracy, and roll, pitch and yaw.
System employed a Pololu IMU and a real-time clock daisy chained I2C to the teensy powered from a separate 5 volt PS.
I'm adding SBUS fields to each record for control inputs and throttle setting. So the last thing I needed to complete data was airspeed.
I have an EagleTree Airspeed Micro-Sensor V3. After the blundering reported on another post, I have it configured for I2C use.
I have some questions.
Does the Airspeed V3 require more current than can be produced by a Teensy 5 volt port?
Could I power it off the plane's 5 volt line?
Will adding the two pull-ups to the I2C bus that was working ok before cause a problem? I haven't checked but assumed that maybe there were pull-ups on one of the other devices?
Has anyone else done this, and of so, am I missing anything?
May 18, 2019, 09:47 AM
Maybe a better question is:
Does the sensor need to be powered by the separate "stand-alone" cable while connected by I2C to my controller?
May 19, 2019, 10:45 PM
Nuts,
Eagletree's I2C address for the v3 airspeed sensor was listed as 0xEA. After spending days trying to figure out why my code wouldn't work, I tried Nick Gammon's wonderful scanner which showed 0x75 as the address when connected to my Nano.
Using 0x75, and adding a 5 millisecond delay to the read cycle, I'm in business.
Is it possible that no-one reading here is doing anything like this anymore?
Question PL8 and Two MPA Boards, Daisy Chained? streetdragster Revolectrix 11 Sep 24, 2017 08:56 PM
Help! Looking for help to code a Teensy 3.2 geekness DIY Electronics 1 Feb 11, 2017 11:42 PM
Alert Daisy Chain: WORLD'S FIRST THREE-GAY MARRIAGE... traceyl Life, The Universe, and Politics 3 Mar 06, 2015 06:00 PM
Question Daisy Chaining Eagle Tree equipments iskoos Eagle Tree Systems 3 Aug 14, 2010 07:54 AM
Discussion Daisy chain balance boards? crumbletop Batteries and Chargers 4 Sep 23, 2009 09:33 PM
