This thread is privately moderated by old4570, who may elect to delete unwanted replies.
May 17, 2019, 10:42 PM
old4570's Avatar
Pod Repair ( Mini DLG pro )
Well ,
Not that the Mini DLG pro was a particularly good DLG glider !
I mean , the UMx Whip could probably give it a run for it's money .
But ! I may as well try and repair it .
To that end !
1) I glued the pod back together with some thick Cyno
2) I scratched up the plastic surfaces
3) I put some light weight glass cloth inside and out using the thick cyno to glue it down .
I went with the thick cyno - Since it did such a good job gluing the two halves back together .
Hopefully I have a functional pod once more .
I am sure the carbon boom will be far more challenging , it's strength is seriously compromised .
Just trying to think of something .
Do I go to a Spring pull system , eliminating the music wire running on the outside of the boom ?
That way allowing me to do a WRAP around where the wing posts are , adding strength .
Discussion Repairing mini dlg pro shaft? BoomerangRuss Hand Launch 1 Sep 18, 2017 08:11 AM
Discussion 1st glider, HK Mini DLG vs Mini DLG Pro... Jimmy JFlyer Hand Launch 3 Dec 26, 2015 06:44 PM
Poll Which one for first DLG. HK mini DLG pro vs HK mini DLG composite VS Eflite Whipit oned Hand Launch 11 Jul 30, 2015 04:16 PM
Question Need Mini DLG Repair Advice kgantz Hand Launch 12 May 15, 2015 05:02 AM
Micro Pod? Pro Pod? Mini Pod!! Ranger13 Foamies (Kits) 4 Sep 20, 2013 11:00 AM
