May 16, 2019, 11:49 PM
Removing old decals on iron on covering
how can this be done? Is there a decal remover fluid? I have tried methyl alcohol and isopropyl alcohol. They discolour the decal and it gets brittle but still sticks.
Rusty
May 18, 2019, 05:42 PM
jpurcha's Avatar
I've never tried it, but gasket cleaner for stubborn adhesives.
Latest blog entry: MAAC Wings
May 19, 2019, 01:59 PM
Captain Dunsel's Avatar
Is this a peel-and-stick decal, or a water-slide decal (I doubt it's the latter as decals rarely adhere to shrinkfilms)?
If the former, as you peel it back, dribble a little acetone or dope/lacquer thinner on the adhesive to dissolve it. Do test the thinner on a hidden part of the covering, though. I don't know of any shrinkfilm acetone, etc., will attack, but one never knows.
CD
May 21, 2019, 01:59 AM
Removing old decals from iron-on covering
Redbird 28 update .. I used acetone and the decals curled up and were able to be wiped off with paper towels. These decals were over 30 yrs old and so is the covering. The covering shows no obvious damage from the acetone. Just take your time. I used Q tips and paper towels.
Good luck.
Rusty
May 22, 2019, 07:16 PM
Dinosaur
Twodor's Avatar
Thanks for the followup Redbird.
I was going to recommend a product by 3M marketed as, 'Adhesive Remover'. I've had good luck with it for a number of similar situations as yours. Its available wherever 3M products are sold such as Ace Hardware stores.
I'm one of those anal retentive guys who remove the previous year's auto license tag decals before applying the new one. The 3M product has worked well for that as well as removing decals and stickers from motorcycle frames without damage to the underlying surface. I also used it to remove some factory stick-on decals from a WWII warbird ARF before repainting it. It had no effect on the heat shrink covering but lifted the decals with a single application following the directions on the can.
Tom
Question Removing Decals from Covering festooks Electric Plane Talk 3 Sep 22, 2018 08:00 AM
Discussion repair old iron on covering??? skylane42 Painting and Finishing Tips 0 Mar 23, 2015 09:22 PM
Discussion Use Gorilla tape to remove what's leftover after pealing off iron-on covering. Roguedog The Builders Workshop 7 Dec 15, 2014 06:18 PM
Help! Removing the glossy shine from iron on covering vonhouzen Painting and Finishing Tips 4 Sep 28, 2011 04:58 AM
How do I remove old covering on my Fling? foamie Hand Launch 5 Jul 10, 2005 10:58 PM
