This thread is privately moderated by Ronakagarwal, who may elect to delete unwanted replies.
May 16, 2019, 03:28 PM
Design and development of a flying wing
Having started from scratch.. i did my theory and design using matlb and excel.
Aim was to start with basic envelop of altitude 500ft
Stall speed : 10m/s
AR : 5
Using few other inputs i did my load calculations and constraint analysis
Then went on to do the weight estimation
And then sizing of the flying wing.
I am now in the assembly stage
I made the flying wing in EPP (pics below)
Started with joining the wings.
Further development will keep you posted.
Span : 909 mm
Root chord : 259 mm
Tip chord : 104 mm
Sweep LE : 30 deg
Airfoil : MH 60
During hot wire cutting trailing edge of the airfoil was found to be too thin and therefore had to keep the tip chord little less than the actual bcz the foam just melted.
Thought of compensating by using choro elevons as attachment.
Still trying to figure out how to mount motor and attach elevons to such a thin trailing edge��.
Any advice will be appreciated ��.
Looking for a cool name too ? Drop in some cool names if you can ��
May 17, 2019, 03:24 PM
Here is my progress with the project. Started assembling today. Pic below
Used choro sheet as elevons. Trailing edge was too thin for motor mount , so i had to add a bit of cut EPP, i fear that will add to the drag but will try to make it more streamlined.
Hope for maiden soon ������������
May 22, 2019, 09:00 PM
old4570's Avatar
Hmmmm ,
1) I would have hotwired the design with Elevons in place ..
2) Then covered in laminating film ( Spars - bla bla )
3) Then cut out the Elevons and taped them .
4) Some foam block in the centre to glue the motor mount to ( Shaped bla bla )
Looks interesting ..
May 25, 2019, 01:01 PM
Well... i would have also changed and done a lot of things but thats is the learning process.. hope to make better on the second one.
So, the maiden is tomorrow.
Will post a pic below.. too many wires .. need to secure them properly.
May 25, 2019, 06:14 PM
old4570's Avatar
Yeah , my first micro wing blew chunks ..
Just spending more time thinking about the next one ..
Really want a Micro Wing .
1s ) F949 flight board with a small brushed quad motor
2s ) XK A800 flight board with XK A800 motor
hmmmmm
Build Log THERMALPLEX DLG - Design, Build, Test, Optimize, Produce, a Flying Wing DLG... RobertTHaas Hand Launch 254 Dec 31, 2015 07:42 PM
Help! How to scale up a flying wing design? Root_ender Modeling Science 6 Sep 20, 2015 01:19 AM
Discussion Flying Model Designer & Developer winans Scratchbuilt Indoor and Micro Models 1 Feb 24, 2006 07:02 PM
Alert Flying Model Product Designer/Developer winans Parkflyers 5 Jan 30, 2006 02:38 PM
Discussion Flying Model Product Designer/Developer winans Vendor Talk 0 Jan 05, 2006 12:28 PM
