May 16, 2019, 09:51 AM
My 2019 Y6 homage to the old Flite Test Anycopter
This is my homage to Flite Test's old 2013 'Anycopter' design, which comprised two circular laser cut plywood hub plates with mounting holes at different angles to allow you to build a tri/quad/pent/hex/octo simply by adding the correct number of square wooden booms. I always liked the idea (& Flite Test themselves!) & had wanted for ages to update the design for 2019 - making it out of carbon fibre & natively supporting standard miniquad electronics (20x20 & 30.5x30.5).
Designed in SketchUp (I'm a complete scrub at CAD/3D modelling), prototypes printed on my Prusa i3 MK3, then the final version CNC cut from 2mm carbon fibre in Shenzhen.
It may be decidedly oldschool, but this is by far the most rewarding & fulfilling multirotor project/build I've done to date - being involved in the whole design/prototyping/manufacturing stages of the frame, rather than buying something off the shelf, is absolutely an experience I can wholeheartedly recommend!
https://www.thingiverse.com/thing:3638846
Everycopter Y6 // Flite Test Anycopter Homage // Custom Carbon Fibre (9 min 23 sec)
Discussion How to test my old batteries Canx Batteries and Chargers 8 Mar 10, 2019 11:47 AM
Discussion my modified flite test fogey scmitchell11 Foamies (Scratchbuilt) 3 Apr 08, 2016 11:14 AM
Discussion Anyone did the motor redundancy test for Naza Y6 mode? as my result, it failed... Jason_cx Multirotor Drone Talk 33 Jul 25, 2013 07:03 PM
Discussion My Ugly homage to the Supergee/DL 50 stefalo Hand Launch 4 May 21, 2008 02:00 PM
