May 16, 2019, 09:28 AM
Carbon fiber wing spar problem
Not sure the best place to post this but I built a 39" EPP 3D model and used a full wingspan flat carbon ribbon about a half inch wide glue upright which I thought would provide great strength and prevent the wing from bending. In the past Ive used much narrower strips with no problem. After a couple of flights I noticed one wing was bending and when I looked at it closely, the spar had broken about 4-5 inches out from the fuse. I added a short piece of the same material in the groove and reglued everything. After drying, I was testing the wing strength and damned if the other wing didnt break at the exact same distance from the fuse. I fixed it the same way and everything seems strong now.
Is it possible that I used a carbon strip that was too wide and this made it weaker and maybe prone to twist and break on an almost 40" wing? My Multiplex Parkmaster is heavier and has a flat spar as well but its not nearly as wide. Ive never had a problem with it but elapor is much stiffer than EPP so it wouldnt need as much reinforcement.
May 16, 2019, 09:51 AM
Sounds to me like you already understand the likely cause - torsion due to weakness of wing material, causing the vertical strip to torque.
A wider strip should have handled compression and tension better than a narrower strip - so assuming both strips were made of the same quality CF, the only thing left is torsion.
Of course, the solution is a CF tube, preferably of square cross-section.
May 16, 2019, 09:59 AM
Is square stronger than round? I have a round tube from a 32" wing that's been ...um... "decommissioned" after a few too many impacts with the ground. If I have any more problems, I will dig out the strip and replace with a tube. I just never thought about a carbon strip being too wide and causing me problems
May 16, 2019, 10:12 AM
Round of 6 mm diameter or more will be alright for a 40 inch span.
Also, like I said, the wider width of the strip was not likely the issue - rather, it was just likely that this plane's wing torqued more than the other plane's wing.
May 16, 2019, 10:14 AM
Thanks for the info
Discussion 5mm x 36” bamboo spar vs carbon fiber for foam wings with wingspan 30” to 70” dropout Foamies (Scratchbuilt) 18 Apr 01, 2018 04:37 PM
Question Tubes for Carbon Fiber Spars (in removable wings) FPV_Habu_Flyer Scale Kit/Scratch Built 7 Aug 07, 2016 12:44 AM
Problem! Carbon fiber wing spar on slow stick [email protected] Parkflyers 8 Aug 30, 2003 11:59 PM
Carbon Fiber Rods for Wing Spars Jim Young Power Systems 7 Dec 21, 2001 12:52 PM
