This thread is privately moderated by the.ronin, who may elect to delete unwanted replies.
May 15, 2019, 02:45 PM
Trader Rating: 31
masterless samurai
the.ronin's Avatar
$6.00 USD
Seller Pays Shipping
For Sale
10x IPEX4 150mm antennas
Got the wrong kind these were too long for what I needed but return window has closed.
They are exactly these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$6 shipped to CONUS.
May 15, 2019, 05:55 PM
Trader Rating: 39
kablake's Avatar
These can be shortened but you would have to be very careful. These are coax cables and the end is the exposed inner conductor (You probably know that). Anyway, if you could remove the outer insulator and external conductor, then shorten the inner coax to the proper length you would be fine.. I worked on these sort of cables for quite a long time but had special tools to do what I suggested..
If you have a very sharp small set of wire cutters you could insert one side of the cutter and work up the external insulator and conductor until you reach the length you want then cut those parts off to expose the inner conductor.. I have even used a very sharp xacto knife inserted under the external conductor and made the cut...
Or sell them for 6 bucks and buy new ones.. LOL
May 16, 2019, 12:06 PM
Trader Rating: 31
masterless samurai
the.ronin's Avatar
LOL yea I know they can be shortened but also know it can be tricky. Hence the sale.
May 16, 2019, 05:50 PM
Trader Rating: 39
kablake's Avatar
I don't blame you at all. just a suggestion.. Even with the proper tools sometimes those tiny Coax cable can be a pain... I don't blame you for just getting new ones...
Good luck with your project!!
Discussion 150mm Rx antenna for graupner RX? RaceMag Radios 2 Apr 25, 2019 08:12 AM
New Product 150mm Triple Feed Patch 5.8GHz 14dBi Pagoda Array FPV Antenna for RC Drone Frimen FPV Equipment 2 Jun 25, 2018 02:41 PM
For Sale 10x 5.8 GHz FPV Antennas = $25 p0st4L FPV Equipment (FS/W) 4 Jun 01, 2017 12:48 PM
Discussion 1.3ghz antenna for 150mm quadcopter Airex Multirotor Drone Electronics 3 Feb 26, 2016 10:43 AM
Found 150mm rx antennas the.ronin Aircraft - General - Radio Equipment (FS/W) 0 Jul 08, 2014 12:28 PM
