This thread is privately moderated by ibcinyourc.com, who may elect to delete unwanted replies.
May 15, 2019, 08:08 AM
Trader Rating: 9
ibcinyourc.com's Avatar
$419.00 USD
Seller Pays Shipping
For Sale
RCGF 50cc Twin V2 50TN TWIN Gas Engine
RCGF 50cc Twin V2 50TN TWIN Gas Engine BRAND new in box, call text or email 314-256-9987 or [email protected]
Description
New Engine,Smooth operator.
CNC made crankcase make it shining and stronger.the gasoline engine also offers strong horsepower and an excellent power-to-weight ratio.
RCGF 50cc T V2
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 50cc(3.05 cu.in)
Bore x Stroke (mm): 1.34 in(34mm) x 1.10 in (28mm)
Carburetor : Walbro
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-8.4V
Maximum Output :4.7HP/3.51KW
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed rang : 1500-8600rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 , Recommend:30:1
(90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 20X10 7600rpm (Standard Two leafs prop)
Suggested Propellers: 19x8, 19x10, 20x8 & 20x10
Suggested Break-in Prop: 20X8
Sparking plug: NGK CM6 Type
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Weight :
Engine:2.5 lb (1154 g)
2XMuffler: 4.45 oz (126 g)
Ignition Module: 5.1 oz (145 g)
Total: Weight: 3.14 lb (1425 g)
Technical Data:
Ignition Battery: 4.8-8.4 NiCd or NiMH, 6.6V LiFe or 2S LiPo pack
Gasoline/Oil Mix: 30:1
Replacement Spark Plug: NGK CM6 or equivalent
dle Speed: 1600 rpm/min
Static Thrust:
29.1 lb (13.2 kg) @ 328 ft (100 m) altitude
25.6 lb (11.6kg) @ 5,900 ft (1800 m) altitude
Discussion RCGF Twin 21cc Gas 2-stroke Engine wuest3141 Engines 8 Oct 05, 2017 10:50 PM
Sold (Used) RCGF 50cc Twin Cylinder Gas Engine! rcidaho Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 08, 2017 06:07 PM
Sold New in box RCGF 50cc Twin cylinder Gas Engine, paid $409, $275 !!! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 23, 2017 01:40 PM
Sold RCGF 50cc gas engine super corsair1 Aircraft - Fuel - Engines and Accessories (FS/W) 7 Oct 31, 2015 03:31 PM
Sold NEW IN THE BOX RCGF 50cc gas engine byronf16 Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 09, 2014 09:27 PM
