This thread is privately moderated by ibcinyourc.com, who may elect to delete unwanted replies.
May 15, 2019, 08:01 AM
Trader Rating: 9
ibcinyourc.com's Avatar
$279.00 USD
Seller Pays Shipping
For Sale
RCGF 35cc RE Rear exhaust & Rear carb r/c aircraft engine gasoline
Brand new in box RCGF 35cc RE Rear exhaust & Rear carb r/c aircraft engine gasoline, call text or email 314-256-9987 or [email protected]
RCGF 35RE (2 min 24 sec)
RCGF 35cc RE REAR Exhaust and rear carb r/c gas engine.
Convenience and power for quarter scale!
With the RCGF 35cc, you get the economy of a gasoline engine in the size of a glow engine. Electronic ignition provides the spark for fast starting. Timing automatically adjusts for peak power throughout the rpm range. And a made-for-flight design ensures the best power-to-weight ratio for performance.
RCGF 35cc
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 35cc (2.13 cu in)
Bore x Stroke (mm): 1.53 in(39mm) x 1.18 in (30mm)
Carburetor : RCGF
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-8.4V
Maximum Output :[email protected]
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed rang : 1500-9000rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 , Recommend:30:1
(90% high octane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 19X8 7900rpm (Standard Two leafs prop)
Suggested Propellers: 19x8 & 20x8,20X10
Suggested Break-in Prop: 19x8
Sparking plug: NGK CM6 Type
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Weight :
Engine: 2.03 lb (923 g)
Muffler: 3.4 oz (97 g)
Ignition Module: 4.4 oz (125 g)
Total: Weight: 2.52 lb (1145 g)
Technical Data:
Ignition Battery: 4.8-8.4 NiCd or NiMH, 6.6V LiFe or 2S LiPo pack
Gasoline/Oil Mix: 30:1
Replacement Spark Plug: NGK CM6 or equivalent
Idle Speed: 1800 rpm/min
Static Thrust:
19.9 lb (9 kg) @ 328 ft (100 m) altitude
19.0 lb (8.6kg) @ 5,900 ft (1800 m) altitude
For Sale CRRC-PRO GP22R aircraft engine (gas) 2.6h.p. rear carb, rear exhaust ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 15, 2019 07:20 AM
Sold RCGF 35cc RE gasoline engine w/ extras Razer8811 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 21, 2019 10:28 AM
Sold CRRC-PRO GP36R 36cc aircraft engine (gas) 4.2h.p rear carb, rear exhaust ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 29, 2016 12:17 PM
Sold CRRC-PRO GP36R 36cc aircraft engine (gas) 4.2h.p rear carb, rear exhaust ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 27, 2016 08:17 AM
Sold PTE36R Pterodacty Aircraft Engine, Rear Exhaust, Rear Carb ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 21, 2012 02:28 PM
