This thread is privately moderated by ibcinyourc.com, who may elect to delete unwanted replies.
May 15, 2019, 07:04 AM
Trader Rating: 9
ibcinyourc.com's Avatar
$209.00 USD
Seller Pays Shipping
For Sale
RCGF 15cc (SE) Gas Engine Beam Mount Version
Brand new in the box RCGF 15SE 15cc gasoline beam mount engine. Call text or email 314-256-9987 or [email protected]
PLEASE NOTE: Please be cautious when purchasing RCGF engines elsewhere, other than RCGF USA or IBCINYOURC imposters/clones are out there claiming to be & saying they are RCGF or adding their company name onto RCGF brand SAYING RCGF contacted them to be distributor it's an outright LIE these could be fake clones, and most likely ARE.
RCGF 15cc (SE)
Parameter
Type : 2 cycle piston valve type gasoline engine for airplane
Displacement (cc) : 15cc (.91 cu in)
Bore x Stroke (mm): 1.3 in (32mm)*0.8 in (19.6mm)
Carburetor : Walbro
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 6-8.4V
Maximum Output : 2.4 hp/1.76KW
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed rang : 1500-15000rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 (recommended : 30:1) (90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 15*6 9000 rpm; 13*6 11000rpm (Standard Two leafs prop)
recommended props :13 x 6, 14 x6,13X8,15X8,15X6
recommended Airplane: 60 size plane,50 size plane,40 size plane
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Weight
Engine: 1.31 lb (594 g)
Muffler: 1.8 oz (51 g)
Ignition Module: 4.4 oz (125 g)
Total: Weight: 1.69 lb (770 g)
Technical Data
Technical Data:
Ignition Battery: 6-8.4 NiCd or NiMH, 6.6V LiFe or 2S LiPo pack
Gasoline/Oil Mix: 30:1
Replacement Spark Plug: M8 1/4-32 or equivalent
Idle Speed: 1800 rpm/min
Static Thrust:
10.2 lb (4.6 kg) @ 328 ft (100 m) altitude
9.1 lb (4.1 kg) @ 5,900 ft (1800 m) altitude
May 15, 2019, 08:05 AM
Trader Rating: 6
Exactly
https://www.rcgfusa.com/product/rcgf-15cc-se/
Wanted RCGF 15cc beam mount engine lipilot Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 07, 2019 10:40 AM
Sold NIB RCGF 26cc Beam Mount Gas Engine Jeff Pfeifer Aircraft - Fuel - Engines and Accessories (FS/W) 4 May 17, 2018 10:31 AM
Found RCGF 10CC Gas Engine BM "beam mount" Rear Carb ddierking Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 21, 2017 06:26 AM
Found Beam mounted 15cc gas engine p51boy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 14, 2015 04:20 PM
Sold RCGF 15CC Gas Engine Beam Mount Version ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 10, 2014 04:01 PM
