This thread is privately moderated by ibcinyourc.com, who may elect to delete unwanted replies.
May 15, 2019, 06:57 AM
Trader Rating: 9
ibcinyourc.com's Avatar
$339.00 USD
Seller Pays Shipping
Sold
RCGF 21cc Twin Cylinder Gas R/C Engine 1/4 32 spark plugs
RCGF 21cc Twin Cylinder Gas R/C Engine 1/4 32 spark plugs brand new in the box.
<iframe width="640" height="385" src="https://www.youtube.com/embed/bQF8RBRIpXM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
PLEASE NOTE: Please be cautious when purchasing RCGF engines elsewhere, other than RCGF USA or IBCINYOURC imposters/clones are out there claiming to be & saying they are RCGF or adding their company name onto RCGF brand SAYING RCGF contacted them to be distributor it's an outright LIE these could be fake clones, and most likely ARE.
Call text or email 314-256-9987 or [email protected]
RCGF 21cc Twins
Smooth operation ; Smaller size
With the RCGF 21cc twin ,you can get more smooth flying experience. It's small, powerful and easy starting, It's a very good choice for small size twin cylinder engine.
RCGF 21cc T
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 21cc (1.28 cu in)
Bore x Stroke (mm): 1.08 in(27.6mm) x 0.67 in (17mm)
Carburetor : RCGF
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-8.4V
Maximum Output :2.8HP /8500rmp
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed range : 1800-9500rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 , Recommend1
(90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 16X8 8100rpm (Standard Two leafs prop)
Suggested Propellers: 16X8,15X8
Suggested Break-in Prop: 16X8
Spark plug: 1/4 32 size
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Found RCGF 30cc Twin, 1/4-32 Angle Plug Engine mesaman4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 28, 2019 08:51 AM
Found RCGF 30cc Twin, 1/4-32 Angle Plug Engine mesaman4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 16, 2019 11:09 AM
Discussion RCGF Twin 21cc Gas 2-stroke Engine wuest3141 Engines 8 Oct 05, 2017 10:50 PM
Sold New in box RCGF 21cc TWIN Cylinder gas Engine !!! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 13, 2017 06:23 PM
Sold Valley View RC 40cc Twin Gas Engine! 1/4-32 Plugs psychotichobbies Aircraft - Fuel - Engines and Accessories (FS/W) 3 Sep 15, 2015 01:13 PM
