This thread is privately moderated by Herb, who may elect to delete unwanted replies.
May 14, 2019, 03:53 PM
Lithium Member
Herb's Avatar
Build Log
F-35 Lightning 70mm EDF by Freewing
Freewing just came out with a new 70mm F-35 Lightning,
https://www.motionrc.com/products/fr...mm-edf-jet-arp
https://www.rc-castle.com/index.php?...ch&search=F-35
https://www.motionrc.eu/collections/...mm-edf-jet-arp
I ordered the Arf-plus version so will install my own power system
The wingspan is about the same as the old v1 and v2 versions which had thrust vectoring and was considerably lighter :
https://www.motionrc.com/products/fr...mm-edf-jet-pnp
A bunch of nice pictures have appeared here :
https://www.rcgroups.com/forums/thum...one&starter=no
Since the wingspan on the model is 82cm, whereas the original has a wingspan of 10.7m (F-35A/B) :
https://en.wikipedia.org/wiki/Lockhe...5_Lightning_II
https://en.wikipedia.org/wiki/Lockheed_Martin_X-35
the scale is approximately 1: 13.0 or ~13-th scale.
May 14, 2019, 03:54 PM
Lithium Member
Herb's Avatar
Mine will be re-painted in the Navy scheme for better visibility, I will paint most of the decals myself ...
May 14, 2019, 08:22 PM
Lithium Member
Herb's Avatar
Or the (somewhat less powerful) FMS 70mm inrunner (2860, 1850kv) fan, very smooth at ~1500 W and 240g weight,
http://www.fmsmodel.com/fms-70mm-duc...v1850-motor-6s
May 14, 2019, 08:26 PM
Lithium Member
Herb's Avatar
From this listing of spare parts it is unclear how large the cheese grater intake is,
https://www.motionrc.com/products/fr...pare-parts-tab
May 14, 2019, 08:30 PM
Lithium Member
Herb's Avatar
Interestingly enough the stock Freewing 240g fan comes with a more efficient inrunner motor (het oem?) .
https://www.rc-castle.com/index.php?...roduct_id=7558
The advertised power is approximately 70A x 22V = 1550W ...
May 15, 2019, 11:56 AM
Lithium Member
Herb's Avatar
Unfortunately this F-35 seems a bit heavier than comparable 70mm jets :
Freewing F-35 70mm empty weight quoted without battery 1700g (2600g with 4500mAh battery ?? )
Freewing Hawk 70mm weight without battery 1450g (2010g with an RT 4500 pack)
The added extra half pound in weight on the F-35 is presumably due to all the added "scale" features added, such as many extra styrene parts, as well as the heavy semi-scale alum gear.
EDIT : My Roaring Top 4500mAh 6S batteries are ~670g :
https://www.roaringtopusa.com/45c-45...is-45c-4500-6s
May 17, 2019, 12:43 PM
Lithium Member
Herb's Avatar
Made some simple hubcaps out of styrene, similar to what I did on the new F/A-18c
May 18, 2019, 11:46 AM
Lithium Member
Herb's Avatar
Thomas B pointed out that the grey on the F-35 is FS 36170, which can be hard to match, but I did find one that is very close.
It is claimed by some that it has a bit of a metallic look to it, so Titanium silver can be added to it.
Reference : https://www.britmodeller.com/forums/...grey-fs-36170/
May 21, 2019, 11:09 AM
Lithium Member
Herb's Avatar
While waiting for the F-35 to get here, I programmed the radio (Futaba 14SG) for tailerons (ch1, ch2) and flaps (ch6).
In the Futaba radio settings this is a "model type" selection, as a flying wing with flaps.
It is my experience with these kind of jets (eg F-16) that the large fully-flying tailerons will provide tons of roll authority, so that the additional ailerons won't be needed.
Among other things, this will allow me later the option to close up the ailerons / flaps completely and fly it on tailerons only.
Today, 11:08 AM
Lithium Member
Herb's Avatar
Getting nearer to the maiden ...
Recommended CG, battery weight and throws, according to manual :
[ Note that according to the location on the drawing and the overall scale, the CG location should be ~36mm, not 4mm, ahead of
the wing mount plastic square. ]
[ Freewing CG's are generally quite conservatives, so the actual best CG could be a few mm's behind that. ]
Today, 04:07 PM
Lithium Member
Herb's Avatar
There is an ingenious guy in Florence Italy by the name of Moreno Lippi who managed to get a modified lightweight styrofoam F-35 to VTOL :
https://www.rcgroups.com/forums/show...landing&pp=100
F35 Vtol - From Vertical Take Off to Horizontal Flight di Moreno Lippi (1 min 8 sec)
New Product Freewing SU-35 Dual 70mm Vectored Thrust EDF PNP (Desert Camo) hobby123 Foamy EDFs 0 Oct 28, 2015 03:10 AM
New Product Freewing F-35 Lightning II 70mm EDF tdford Foamy EDFs 4 Aug 21, 2013 10:04 AM
Cool The F-35 Lightning, 70MM, 360- degree, Multi- Vectored Thrust, EDF Jet Build video JetA320 Foamy EDFs 15 Feb 21, 2010 08:37 PM
