Oct 10, 2019, 07:48 AM
capt soap's Avatar
Once a bubblehead always a bubblehead. USSGlenard p Lipscomb. Ssn685.
Oct 10, 2019, 08:19 PM
Electric Coolhunter
Thomas B's Avatar
Originally Posted by Herb
Had a chance to see the real F-35 fly at the Great Pacific Airshow today ... It is very very noisy !
The noise is a fairly unavoidable side effect of converting dead dinosaurs into 43,000 lbs of thrust...
Latest blog entry: RC events for 2019!
Oct 11, 2019, 12:49 PM
Lithium Member
Herb's Avatar
That F-35 rumbling noise was pretty awsome ... The A-10 was quiet in comparison, the only ones the came close noise-wise were the TB's
The model ... well it makes no difference 5bl, 13bl or 17bl it has absolutely no relationship to the sound of the real one
https://www.rcgroups.com/forums/show...0#post42028121
Oct 11, 2019, 05:21 PM
capt soap's Avatar
Think about the thrust increase over previous generation motors. The F15 had a Pratt the put out about 24000 lb of thrust. Now where at 43000lb in a simpler size powerplant. Noise is freedom.
Oct 12, 2019, 10:32 AM
how many pounds of thrust per dollar?
interesting question IMO
Is The F-35 Worth $115 Million? (23 min 50 sec)
Oct 12, 2019, 11:09 PM
capt soap's Avatar
Went down late today.. swampy area. May never see it again. Time to put the high boots on tommorrow. Crashes are bad, but never seeing your jet again is the Worst!
Oct 12, 2019, 11:12 PM
I review RC Products
GBLynden's Avatar
Oh man! Any idea as to what caused the crash?
Oct 13, 2019, 09:33 AM
fredmdbud's Avatar
Originally Posted by mopetista
The Freewing 70mm 6S model sure is worth its cost IMO
Latest blog entry: Digital LED Voltmeter
Oct 13, 2019, 09:51 AM
I would have preferred the larger wingspan of the c variant, but I will admit that FW made a very nice model, and chose a good EDF with their efficient inrunner. Like how they made the tailerons solid, but IMHO they could have made a plastic cheesegrater part to cover the large cheater hole (in a German thread someone shortened the L-39 plastic part to fit the (slightly modded) cheater of the F-35 (he also modded for solid ball link linkages, taped the hinges, and painted servo covers and the rest, see here: http://www.rc-network.de/forum/showt...=1#post4874161)
Oct 13, 2019, 06:48 PM
capt soap's Avatar
At our club 4 planes went down in the same corner. Don't know, 5g maybe. Did find it today in very tall weeds. Just mashed the front of the fuse.
Oct 20, 2019, 06:07 PM
EDF rules... :)
AirX's Avatar
Flew twice this morning. Everything went well after putting the new wheel covers on fuselage.
When I crashed it on the first maiden because I had too touchy setup they were not in stock. Plane was a lot faster with them.
Cheers,
Eric B.
Oct 28, 2019, 05:53 PM
Where did that tree come from?
urrl's Avatar
Jet doesn't look too pretty now after the crashes but at least I know more about it's limitations.
Freewing F-35 Cuban 8 Practice (5 min 1 sec)
Oct 28, 2019, 07:46 PM
fredmdbud's Avatar
https://www.youtube.com/watch?v=2ibu...ature=youtu.be
If you ain't crashin', you ain't flyin'
Oct 29, 2019, 07:43 AM
Landing is not optional
JamesonC's Avatar
Need some help guys...
Haven't flown the F35 in a while so I took it out Saturday. Had some weird stuff happening in flight that I don't remember happening before and hoping y'all can help. When making 3/4 to full throttle passes, if you pull the power out to idle, the plane pitches up pretty hard. Somewhere around 30 degrees probably. It flies straight as an arrow under power, just pitches up when you go to zero throttle. Puzzled me and I need some help. Thanks!
Oct 29, 2019, 08:19 AM
All aboard Flight 666
grant22's Avatar
That is strange
I commonly do low passes over the runway, full throttle, then shut off the throttle for the sound effect.
No pitch change whatsoever.
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 2405 Jul 09, 2019 07:18 PM
New Product Freewing F-35 Lightning II 70mm EDF tdford Foamy EDFs 4 Aug 21, 2013 10:04 AM
Discussion Starmax 70MM F-14 vs. Freewing's Eurofighter and Su-35 kchen95 Foamy EDFs 14 Jul 15, 2012 05:07 PM
