Sep 03, 2019, 08:36 AM
Landing is not optional
JamesonC's Avatar
Originally Posted by capt soap
Anyone get there's on radar? I'm thinking maybe 115mph.
Originally Posted by grant22
Maidened mine this morning.
I used Herb's travel values and the book's new CG reference.
Only problem was Herb's elev travel was measured trailing edge, I measured from leading edge. To be safe, I did a dual rate on the elev with a lower value (since at the time of maiden, I didnít know his reference point)
Takeoff with my erroneous elev travel was a handful, immediately switched the elev to low rate and worked great. Coincidentally, itís accidentally Herb's elev value, measured from the trailing edge.
Anyway, flies outstanding. 13 mph wind today. I flew with AS3X off, then on, and surprisingly it handled well with no gyro. The AS3X locked it in more, as youíd expect.
Those that say it has to land fast, Iíd say work on moving your CG back possibly or holding a nice flare at touchdown. Mine slows down NICELY.
Reminds me a lot of my FW F-16 70mm.
My 5000ís were full aft and netted me 5:30 flight times with mixed throttle. Hereís a pic of the gps'd speed reading (crosswind)
Pretty incredible! Radar readings on mine (with a 4000mah) were 113mph as well.
Sep 07, 2019, 11:22 AM
Where did that tree come from?
urrl's Avatar
Morning flight using new Galaxy Note 10 Plus.
Freewing F-35 using Galaxy Note 10 Plus (5 min 13 sec)
Sep 14, 2019, 09:59 PM
EDF rules... :)
AirX's Avatar
Motion has posted spare parts for the F35.
Cheers,
Eric B.
Sep 14, 2019, 10:39 PM
capt soap's Avatar
Finally !!
Sep 15, 2019, 12:35 AM
Originally Posted by rvincent
Faster than the Havoc in a dive
how embarrassing lol ..
Sep 17, 2019, 01:11 PM
capt soap's Avatar
Just ordered a new fuselage, does it include the gear door covers?
Sep 17, 2019, 02:07 PM
EDF rules... :)
AirX's Avatar
My first replacement did not, I used the main gear covers from the first one and had to make one for the nose gear cover as my first crash took it out.
Sep 17, 2019, 02:11 PM
JamesonC's Avatar
You have to buy them separate but they are only $6 for all 3.
Sep 19, 2019, 12:39 PM
EDF rules... :)
AirX's Avatar
They are available at the moment.
Eric B,
Last edited by AirX; Sep 20, 2019 at 09:27 PM. Reason: Meant that they were available.
Sep 19, 2019, 01:24 PM
All aboard Flight 666
grant22's Avatar
I’ve been able to log around 40 flights with this bad girl and it just gets better
It’s a rocket, easily my fastest jet. It’s handling is second to none (in my experience) and it lands with absolute grace every time. It WILL land slow, if you make it.
I’m still actually surprised how stable it is. I was expecting a handful based off its stubby wings.
Once again, nice job FW and MRC
Sep 21, 2019, 09:20 PM
unleaded218's Avatar
ok I have just about got the damaged model ready for flight I have taken on board sugestions re lifting the nose wheel to help with grass take off and as the front of mine had some damage I decided to put a 10mm(3/8") blocks under the retract , the wheel protrudes below the cover but if it helps I can live with that
Sep 21, 2019, 09:24 PM
The pic
Sep 21, 2019, 09:48 PM
Picture of the plane after the maiden crash and the repaired and with the Australia decals on
Sep 21, 2019, 10:07 PM
Fly,Crash, Burn,Fix, repeat
Gravythe Clown's Avatar
Just got back from the LNAS air show. I found my repaint. VfA-125 Rough Raiders number 420.
Gravy
Sep 22, 2019, 09:29 AM
capt soap's Avatar
I keep hearing the remarks about how fast the F35 is. It seems about the same as my 80mm powered mirage. Around 120 mph.
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 2405 Jul 09, 2019 07:18 PM
New Product Freewing F-35 Lightning II 70mm EDF tdford Foamy EDFs 4 Aug 21, 2013 10:04 AM
Discussion Starmax 70MM F-14 vs. Freewing's Eurofighter and Su-35 kchen95 Foamy EDFs 14 Jul 15, 2012 05:07 PM
