May 14, 2019, 03:39 PM
Originally Posted by JamesonC
To each their own, but I certainly don't think this F35 or the 70mm F16 look "pathetic" for sure!
Don't get me wrong. They are the best to date
Out there. But their small size is simply not appropriate for larger airfields ;-) . Just get
The bigger Jets.
Love the F35 in the photos for good visibility
In the sky. :-)
May 14, 2019, 03:43 PM
Lithium Member
Herb's Avatar
Nice !
I see some suitable modifications on mine (ordered arf-plus kit), re-paint in Navy scheme and tailerons only (close all gaps on the ailerons)
The spar seems to sit above the duct ... and nothing else is in the way
May 14, 2019, 03:50 PM
Originally Posted by Herb
Nice !
The spar seems to sit above the duct ... nothing else is in the way
Why don't we all ask for the
Grey version Arf plus F35.
They could do that like they offered the
Grey version F18C. No decals applied on the
Fuselage.
Please do, god MotionRC.
Offer grey Arf plus F35. No decals applied. Please :-)
May 14, 2019, 04:13 PM
Originally Posted by edwen303
Very good looking scale F-35. Guess the flying weight is so much more than V2, the TV was opted out. He was flying on a 5000mah pack too
Pretty sure someone along the way will experiment on flaperon setup for this bird
The power plant's specs looks very impressive. 6s 70 Amp at 5.5 lb thrust: https://www.rc-castle.com/index.php?...roduct_id=7558
Assuming their specs is true. ;-)
Outside Diameter : 73.0mm
- Ducted Fan Length : 59.0mm
- Rotor DIameter : 69mm , 12 Blades
- Weight: 240g
- Working Voltage: 6S 22.2v
- Motor : 2957 2210Kv Inrunner Brushless Motor (Installed)
- Static Thrust: Around 2450g At 22.2v (70A)
Installed, will get at best 80% .
So it could be 1960gr thrust on a
2600gr F35.
About.... 0.75 thrust to weight ratio at best. :-)
May 14, 2019, 04:27 PM
I really like the looks of this one although I am somewhat concern with the huge cheater on the bottom. I’m sure it’s good for performance but it’s a very large opening that’s close to the ground. Easy for Fod ingestion. Thoughts?
May 14, 2019, 04:52 PM
HellHathNoFury's Avatar
- Weight: 240g
2600gr F35.
1600W of draw.. Smooth as Silk
May 14, 2019, 04:55 PM
Originally Posted by HellHathNoFury
1600W of draw
In Thrust we trust :-)
70x6x3.7 = 1554 watts
1554watts/ 5.7lb F35 = 272 watts/lb.
May 14, 2019, 05:31 PM
Doesn't even VTOL! 0/10
(kidding)
May 14, 2019, 05:52 PM
Retired US Navy
Evan D's Avatar
No kidding as far as Iím concerned. Doesnít leave the starting gate... no sale.
(kidding)
May 14, 2019, 06:30 PM
(kidding)
The decals said F35A, airforce version
Not F35B or F35C .
So no VTOL for the Airforce F35A. It
Is correct..
May 14, 2019, 06:41 PM
I know for sure some flyers
Will put an 80mm fan on this F35. Why not ;-)
That's the way it is ... ha ha...
May 14, 2019, 07:20 PM
Got all excited when I seen this one up this morning, almost got to trigger happy and ordered it before I read the specs, just about to hit the buy button when I seen 70mm, man talk about letting the air out of your tire, thought is was a 80 or 90mm..
Oh well, it looks nice and the 70mm guys deserve something like this, thought about it but just not into 70mm, unless it's a twin...............
May 14, 2019, 07:23 PM
Fly and let Fly!
Cocg's Avatar
Hey V8 Truckin.....
Should you not take the "V3" out of the title?
May 14, 2019, 07:48 PM
Want 90mm jet?
There are great 90mm F22, F18C, F4 ... :-)
And there are great 70mm F35, F16... :-)
Also 80mm Mig 21, F5, mirage 2000 , Yak 130 ... :-)
Even 64mm F18, F22 ...
Everyone gets something for fun.
That is fair .
May 14, 2019, 08:02 PM
The bigger Jets.
In the sky. :-)
By this logic if Iím flying on a giant dry lake bed I should only use a full size plane because the field is so big??
New Product FreeWing 70mm F-35 w/ Thrust Vectoring bhatch21 Foamy EDFs 2405 Jul 09, 2019 07:18 PM
New Product Freewing F-35 Lightning II 70mm EDF tdford Foamy EDFs 4 Aug 21, 2013 10:04 AM
Discussion Starmax 70MM F-14 vs. Freewing's Eurofighter and Su-35 kchen95 Foamy EDFs 14 Jul 15, 2012 05:07 PM
