May 14, 2019, 04:10 AM
How do you test your VTOL fixed-wing?
Fixed-wing VTOL testing gradually becomes a headache these days, due to the strict restriction policy for flying drones here in Shenzhen China. Finally, we found a good place to conduct the test: one stone crusher plant, about half an hour by car from our office.
An ideal place, no power line and high building around, far from the airport of course. The main purpose was to test the VTOL stability and endurance this time.
Before taking off, parameters of autopilot need to be adjusted according to the environment. One guy controlled the fixed-wing through RC controller, while another guy operated the ground station. The VTOL drone shook too much for the first flight.
Autopilot adjusting before the VTOL fixed wing take off (0 min 14 sec)
Finally, it took off stable and flew as per the programmed routine.
VTOL fixed wing take off successfully fly as pre setup route (0 min 39 sec)
How do you test your VTOL fixed wing? We are open to your suggestion.
Discussion How do you fix your canopy? Flying Pitcher Beginner Training Area (Heli-Electric) 19 Aug 01, 2017 05:50 AM
Question How do you see how many voltage your battery is discharged to? TheSymaMan Batteries and Chargers 6 Oct 24, 2015 03:45 PM
Question How do I wire a VTOL plane/quadcopter? crazyrcdesigner VTOLs 2 Sep 13, 2015 10:15 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Discussion How do you fix your hinges? airmcn_3 Composites Fabrication 11 Apr 24, 2010 04:44 AM
