Jul 09, 2019, 05:58 PM
San Diego California
Walbro fuel pump for water pump FPC-1 Vs K-10
FPC-1 is consisted of aluminum sheets and metal springs while K-10 has all plastic & rubber parts.
I think K-10 is more suitable for RC gas engine cooling pump for its anti corrosion ability.
Jul 18, 2019, 11:29 AM
Rescue boat in action ( for my F-41)
The idling set was too low and probably needed more warming up. Anyway, the motor stopped at middle of the pond and rescued.
RC rescue boat in action (3 min 4 sec)
Jul 18, 2019, 12:41 PM
Running good
As mentioned previously, the requirement of a water pump is not critical as long as the boat is not left idling for long since movement of the boat should flow sufficient water at modest speeds. Besides this, I found the water flow is not proportional to the engine rev. The pulse drives the diaphragm has certain frequency range for its effectiveness. Again, it is not critical but I simply think higher rpm needs more cooling water flow.
F 41 third run (2 min 7 sec)
Jul 24, 2019, 05:56 AM
Engine mount
Replaced the separate steel plate engine mount to aluminum ladder frame type and through strut bolts. This is a compromising result of strength and vibration dumping after anti-vibration rubber stud was broken.
Aug 07, 2019, 06:19 AM
Prop rpm by sound
Actually this is bad video (focus ring moved when I wore it ) but I can hear the engine sound of prop goes above and under surface when it was going over the bumps.
RC Boatworks Stryker F-41 engine sound check (2 min 47 sec)
Discussion Looking for New or slightly used PArkzone F-27Q Stryker zagiflyer67 Electric Plane Talk 1 May 29, 2016 06:19 PM
Discussion Untapped RC Boatworks Trick 46 mono hull for sale BHChieftain Racing Boats - Internal Combustion 0 Jul 02, 2015 06:52 PM
Video Stryker F-41 video ken0276 Dock Talk 5 May 04, 2008 04:29 AM
