May 13, 2019, 10:10 AM
INTEGRITY FIRST
high wing's Avatar
Mini-HowTo
remove monocote
What is the best way to remove monocote?
Jun 06, 2019, 03:05 PM
Gratter's Avatar
No best way. Sometimes it will peel off. Sometimes you have to use some heat to soften the adhesive then peel it away and sometimes you have to sand.
Jun 12, 2019, 08:10 PM
I found using a heat gun to soften the adhesive works best. You will still get some color remaining on the wood but I remove the remaining color with acetone or lacquer thinner.
This method also works well with Ultracote.
Discussion Removal really old monocote.? dankar04 Thermal 7 Apr 07, 2016 04:21 PM
Question How can I remove some decails on monocote? cwolfe Scale Kit/Scratch Built 5 Dec 27, 2011 09:43 AM
? on Monocote Removal mag1 Scale Kit/Scratch Built 2 Mar 09, 2005 12:24 PM
How do you remove Monocote? Claude17 Electric Plane Talk 3 Aug 02, 2001 11:57 PM
