May 12, 2019, 10:09 PM
30 yrs. Of Aircraft flying!
epoweredrc's Avatar
Where to find small spot lights for tail of rc plane?
So i want to add some lights to the tail of my Timber X and noticed that one of the rc companys uses these tiny spot lights on the tail to light up the fin. i like to get some and give them a try but not found much online. anyone know where i can get some that will run on 2 or 3 s voltage?
also what type of wire do most folks use? something small but easy to solder
May 14, 2019, 08:02 AM
epoweredrc's Avatar
Anyone at all?
May 15, 2019, 09:14 PM
epoweredrc's Avatar
found these but not sure
https://www.rcplanet.com/mytrickrc-s...ht-kit-mykft4/
Jul 09, 2019, 08:25 PM
dimensionengineering.com for starters
Jul 09, 2019, 08:27 PM
Motion rc
look under the electronics tab
Jul 10, 2019, 09:44 PM
pnubtrnjly's Avatar
I am looking for the first time.
Zero experience. But i found this.
https://flytron.com/led-light-system...tion-pack.html
I will look at Birddog 1 suggestions next.
Thanks everyone!
Aug 12, 2019, 12:24 PM
wolframore's Avatar
try www.evandesigns.com
https://www.modeltrainsoftware.com/c...ghting-circuit
I plan on doing a how to soon... been doing some research and have a UMX Cessna to lightup, just got done soldering LED's but you can buy them prewired at the site above.... will save you many hours plus it's got the right resistors for whatever voltage you want. I think I need to re-do mine with even thinner wire... I'm using 28ga but the insulation adds weight.
Aug 14, 2019, 04:25 PM
You're killin' me Smalls
BrownEyedFool's Avatar
Horizon sells the UMX Timber led light kit as a separate part
Aug 28, 2019, 02:18 AM
Slowly's Avatar
We have a very cool company in Austria here in Europe for stuff like that.
Have a look.
thttp://www.unilight.at
Sep 02, 2019, 08:32 PM
When adding lights to my planes I use wire for winding our electric motors very light and it is coated so do not have to worry about shorts.
Only thing when soldering you nave to melt the coating off first before tinning, the wire is actually very strong for it`s size.
Discussion Where to find cases for small/med quads? zim2323 Multirotor Drone Talk 6 Jul 07, 2016 01:21 PM
Discussion Where to find super thin and light heatshrink for ESCs and vtx/rx anarchy187 Multirotor Drone Talk 3 May 22, 2016 08:49 PM
Discussion Where do I find build logs for sail planes? Dan23024 Sailplane Talk 2 Mar 10, 2016 03:17 PM
Help! Trying to find plans for small scale balsa model aircraft(non-rc) FlyingMaddLadd Balsa Builders 2 Jan 02, 2016 04:34 AM
Discussion A simple, inexpensive lighting alternative for small RC planes Stingray8854 Beginner Training Area (Aircraft-Electric) 25 Feb 02, 2013 05:46 PM
