Jul 15, 2019, 09:50 PM
Very nice Airplanes. My airplane also turns very tight. It’s very important to keep the airplane at faster speed. I also made a small circle and had to run backwards to keep lines tight. Now I practice circles up high and try to keep circles bigger and keep plane going at faster speed
Good luck !
Gene
Jul 16, 2019, 08:07 PM
Thanks. I tried it with my brother. Added another washer at front engine mounting bolts. Better tension, can fly better, but still under the limit i think. Ill saw the rudder and add more deflection!
Jul 16, 2019, 08:44 PM
Old Timer
The Kiwi's Avatar
Rudder offset is nothing but a chimera! It doesn't do anything useful!
Jul 25, 2019, 10:31 PM
Are you suggesting tip weight? I always built woth right rudder, and this is by far the "straighter" rudder. Any adcoce will be apreciated!
Jul 30, 2019, 01:28 AM
fiery's Avatar
Club member's new build Akromaster. Extended span and modified tailplane. MARZ 2.5 c.c. diesel power. I will critique and if all is in order test fly it this week-end.
My old Akromaster (also MARZ 2.5 diesel powered) flies with authority. No lack of line tension on 52" lines.
Jul 30, 2019, 08:57 AM
Old Timer
The Kiwi's Avatar
For level flight, and for violent maneuvering, rudder offset is a lousy idea, always has been. it is possible that a part-time rudder, deflecting only at certain times, might be OK for the smoother maneuvers of precision aerobatics. Al Rabe rigged some of his planes that way.
The right setup of line rake, line length, and tip weight is the best assurance of good line tension.
Kiwi
Jul 30, 2019, 12:43 PM
Fiery: same as mine, i have a greater wing, avoided cutting spars, as many advice. Ill be waiting for your critics
Kiwi: i believe the speed is OK (4seg lap time) with good line tension in level flight. The line tension starts when i start climbing on a loop, whenbi lose some speed tension reduces quick below safety margins. Im suspecting i need to add more tip weight.
Both: Forgot to mention, my CG is near the leading edge limit (1 inch; the margin y between 1 and 1- 1/2 inches). Maybe is related, not sure really.
Thanks for your support friends!
Aug 19, 2019, 12:01 AM
fiery's Avatar
Akromaster flew beautifully. Now well and truly ‘blooded’, as can only happen under diesel power .
Today, 12:24 AM
Lol, what a mess! Never tried a diesel engine. I have a fellow airmodeler who likes old school F/F and uses an old british diesel engine. It is a very beautifull one, and he always says its a Rolls Royce (cant remember the brand, but suposedly was a RR department or something).
Today, 11:11 AM
Now that's funny Derek ! Love those diesels .
Mike1484
Discussion Sig Akromaster gene6029 Control Line 90 May 11, 2019 03:52 PM
Discussion Sig Akromaster With OS LA 25 MikeCr Control Line 28 May 05, 2016 10:20 AM
Discussion Sig Akromaster build tips? BBreyer Control Line 5 Apr 25, 2012 08:50 PM
Discussion Sig Akromaster jhunter Control Line 2 Apr 03, 2012 07:13 AM
Discussion Sig Akromaster prices? AT1984 1/2A Planes 4 Aug 01, 2011 01:55 PM
