May 12, 2019, 04:16 PM
Help!
Bad encoder?
I am trying to make my own quadcopter that has a Pixhawk Mini 4 as a FC, and using a Spektrum DX6e as a controller, and using Mission Planner ArduPilot.
We are having some trouble with something, but I don't know what the root cause is. When we connect the PPM Encoder into the Pixhawk's PPM port, the lights turn on on the Encoder, but when we try to do an RC calibration on MP, it is not connecting as we see no bars, and when we try to move the throttle, there are no green bars. Only sometimes when we start to play around with the connection (i.e removing it, plugging it back in) it does connect but it seems random..Sometimes it connects on my firs try, or it connects on my 30th try. Is this because of a bad Encoder or bad Pixhawk port? My gut tells me this is the Pixhawk but I hope I am wrong.
Thanks.
May 13, 2019, 04:19 AM
RCvertt's Avatar
Sounds like a bad wire or connector. The device its self might be good.
May 16, 2019, 08:26 PM
we figured out how to connect it.
We disconnected receiver from encoder, plugged in Pixhawk to MP, connect encoder to receiver, turn on controller, and then connect the Pixhawk to MP.
We even bought a new encoder and would not work without going this route.
We have no idea why it would work this way, and Im not sure if this is a viable solution.
May 17, 2019, 01:54 AM
RCvertt's Avatar
That sounds a little involved. Thanks for sharing a solution.
Discussion help on a bad motor or bad FC , bad ESC ? drone acting weird today boubou13100 Multirotor Drone Electronics 2 Nov 13, 2016 08:01 AM
Help! Can't tell if it's bad ESCs bad Motors, or just bad luck? bobthemagicmoose Multirotor Drone Electronics 1 Jun 24, 2016 11:15 AM
Question PPM Encoders - Are they all bad? zeebo101 Multirotor Drone Electronics 0 Jul 24, 2015 12:57 AM
