This thread is privately moderated by Merch, who may elect to delete unwanted replies.
May 09, 2019, 01:35 AM
Merch's Avatar
Mini-Review
JJRC X9 Heron GPS 5G WiFi FPV with 1080P Camera Optical Flow Positioning RC Drone
https://www.banggood.com/JJRC-X9-Heron-GPS-5G-WiFi-FPV-with-1080P-Camera-Optical-Flow-Positioning-RC-Drone-Quadcopter-RTF-p-1422116.html coupon: efbc2b
Had a stuck gimbal so took it apart seems to be ok for now with a newer board version V2.3
Full Video review to come!
JJRC X9 Heron GPS 5G WiFi FPV with 1080P Camera Optical Flow Positioning RC Drone Quadcopter RTF
Description:
Brand Name: JJRC
Item NO.: X9
Item Name: Heron Drone
Controller Frequency: 2.4Ghz
Channel: 4-Channels
Camera: 1080P (adjustable angle)
Motor: Brushless Motor
Battery: 11.4V 1000mAh Li-ion Battery (Included)
Flight time: About 14-15 mins
Charging time: About 250mins
Radio Mode: Mode 2 (Left-hand Throttle),WiFi APP
Control Distance: 1000m
Max Speed: 20km/h
Compatible with Additional Gimbal: No
FPV Distance: 200 - 300m
Transmitter Power: Built-in rechargeable battery
Quadcopter Size: 14.8 x 14.5 x 6cm
Quadcopter Weight: 258g
Color: Black, White (Optional)
Features:
- GPS Positioning. Under GPS mode, when the aircraft receives the signal from satellites, it will position where it is.
- 5G WIFI FPV. 1080P videos and photos, 720P real-time transmission.
- 1080P HD Camera Gimbal. It is equipped with 1080P camera, tuned amazingly to capture pictures and videos from the sky, also with two-axis brushless gimbal,helping the drone record vibration-free footages.
- Optical Flow Positioning. It captures image data with the drone's bottom camera, then uses the optical flow to improve the smoothness of the control.
- Brushless Motor. It is equipped with the brushless motor, which makes your flight more powerful.
- Altitude Hold Mode. In altitude hold mode, the drone maintains a consistent altitude while allowing roll, pitch, and yaw to be controlled normally.
- One Key Takeoff /Landing. One press automatically taking off or landing, the drone will take off or go back to the position where it took off.
- One Key Return. One-key return function makes it easily to find the way home.
- One Key Following Mode. In the mode, the drone will fly following the player to capture the beautiful moment
- Point of Interesting Flight. Choose one point, then the drone will fly around the point in a circle
- Tap to Fly. Choose one point, the drone will fly toward the aim straightly.
Function: Forward/backward, Turn left/right,Up/down, Camera, FPV, GPS, Altitude Hold Mode, Continuous Shooting, Headless Mode, One Key Automatic Return, One Key Follow, One Key Landing, One Key Taking Off, Optical Flow Positioning, Point of Interest
Package Included:
1 x JJRC X9 Quadcopter
1 x Remote Controller (Battery Included)
1 x 11.4V 1000mAh Li-ion Battery
1 x Balance Charger
1 x USB Charging Cable
2 x Spare Propeller
1 x L-type Hex Wrench
1 x User Manual
May 10, 2019, 07:22 PM
Merch's Avatar
Updated with some pictures.
May 23, 2019, 03:42 AM
Marcofan76's Avatar
nice tread, here my video test, good gimbal
JJRC X9 - Recensione su ActionCamItalia (4 min 12 sec)
New Product JJRC X9 Heron GPS 5G WiFi FPV with 1080P Camera Optical Flow Positioning Quadcopter BGKevin Multirotor Drone Talk 20 May 23, 2019 03:40 AM
Discussion JJRC X9 Heron 1080P GPS 5G WiFi FPV Brushless RC Drone Optical Flow Positioning RTF GeekBuying Geekbuying.com 0 May 07, 2019 02:11 AM
Discussion JJRC X9 Heron 1080P GPS 5G WiFi FPV Brushless RC Drone Optical Flow Positioning RTF GeekBuying Geekbuying.com 0 Mar 29, 2019 03:40 AM
