New Product
GEPRC CinePro (4K F7)Here the first few specs (it will be updated with new information later).
(reserved for review)
This . . . or smaller ??
Geprc GEP-CX Cygnet 115mm 2 Inch RC FPV Racing Drone https://www.banggood.com/Geprc-GEP-C...r_warehouse=CN Spensive lil' bugger even with the F4 . . . They sure seem to like this shape . . . |
I absolutely love my GEPRC Cygnet CX2. Out of the box, it was far more tractable than my factory-built Armattan Gecko even (my first "big" quad, all the others are Whoops). It would be a great basis for this upgraded 4K version. I also put prop guards on mine (although they are the open type, not ducts) and it flies no differently.
I'm holding out for the upcoming Hawkeye Split 4K though...which will have stabilization. |
I just received mine yesterday. Only had time for a quick test flight. It was getting blown around a bit with the wind but it felt pretty locked in all things considered.
Here's a clip:
What sort of flight times you see? What size battery you're using? General question: what is a F7 flight controller? And, is Betaflight ever going to add the option to turn the video recording on/off from the transmitter while flying? I don't think that is too tough a feature to add but I could be wrong. |
I'm using a Turnigy Nanotech 650mah 4S. Hard to tell from the initial test flight but i'm hoping I can get ~4 minutes with these. I also tried a BetaFPV 450mah 4S but I think that one is a little too small for me. I think with faster flying it would be hard to get more than 2.5 minutes on that one. Controlling the camera OSD from the TX would be really nice! If there is a way to do that I would like to figure it out. |
Betaflight config backup
Hi,
I’m looking for a copy of the original betaflight configuration if someone can backup his cinepro4k please? I updated to the latest BF without backing up the configuration and I have a few settings I want to validate. Thanks in advance! |
I will post it when I get a chance to plug it in. |
This is not totally stock, but I have only made minimal changes:
# diff # version # Betaflight / EXF722DUAL (EX7P) 4.0.0 Apr 11 2019 / 07:08:48 (9ad2cc844) MSP API: 1.41 # start the command batch batch start board_name EXF722DUAL manufacturer_id # name name CinePro F7 # resources # timer timer A00 0 timer A03 0 timer C08 0 timer C06 0 timer C09 0 timer C07 0 timer B01 0 timer B00 0 # dma dma pin C08 NONE dma pin C07 NONE # mixer # servo # servo mix # feature # beeper # beacon # map map TAER1234 # serial serial 1 8192 115200 57600 0 115200 serial 3 64 115200 57600 0 115200 # led led 0 6,7::CTOB:0 led 1 7,7::CTOB:0 led 2 8,7::CTOB:0 led 3 9,7::CTOB:0 led 4 6,8::CTOB:0 led 5 7,8::CTOB:0 led 6 8,8::CTOB:0 led 7 9,8::CTOB:0 # color # mode_color # aux aux 0 0 0 1900 2100 0 0 aux 1 1 2 900 1175 0 0 aux 2 2 2 1325 1700 0 0 aux 3 13 3 1700 2100 0 0 aux 4 35 1 1750 2100 0 0 # adjrange # rxrange # vtx # rxfail # display_name # master set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 150 set baro_hardware = NONE set fpv_mix_degrees = 25 set dshot_idle_value = 650 set motor_pwm_protocol = DSHOT600 set vbat_warning_cell_voltage = 360 set yaw_motors_reversed = ON set small_angle = 180 set pid_process_denom = 1 set osd_tim1 = 2562 set osd_vbat_pos = 2497 set osd_rssi_pos = 2433 set osd_tim_2_pos = 2487 set osd_flymode_pos = 2049 set osd_throttle_pos = 66 set osd_vtx_channel_pos = 2520 set osd_current_pos = 2464 set osd_mah_drawn_pos = 2507 set osd_craft_name_pos = 2068 set osd_warnings_pos = 2441 set vtx_band = 5 set vtx_channel = 4 set vtx_power = 3 set vtx_freq = 5769 # profile profile 0 set dterm_lowpass2_type = PT1 set dterm_lowpass2_hz = 100 set level_limit = 65 # rateprofile rateprofile 0 set roll_rc_rate = 110 set pitch_rc_rate = 110 set yaw_rc_rate = 113 set roll_srate = 73 set pitch_srate = 73 set yaw_srate = 75 set tpa_rate = 25 # end the command batch batch end # |
Thread Tools | |
Similar Threads | |||||
New Product | Geprc Stable Pro F7 Stack Dual Gyro F7 Flight Controller & 35A BLheli_32 4in1 ESC & 5 | alex_nikiforov | Banggood.com | 0 | May 06, 2019 06:11 AM |
Discussion | UPair-One ***Cheapest 2K/4K Camera Quad*** [442$ for 4K version] | Quadbuddy | Banggood.com | 219 | Oct 24, 2017 02:49 AM |
New Product | Omnibus F7 Pro- $40 F7 AIO (F7 FC, BF OSD, Current sensor) | D Gains | Multirotor Drone Electronics | 1 | Sep 06, 2017 07:50 AM |
New Product | GEPRC New X frames - GEP-ZX4, GEP-ZX5 & GEP-ZX6 VX5 QX5 | sevet | Mini Multirotor Drones | 62 | Sep 05, 2017 09:13 PM |
