May 06, 2019, 08:01 AM
Merch's Avatar
New Product
KST A15-1810 7.4V 18kg 42g High Torque Metal Gear Digital Coreless Servo For RC Airpl
https://www.banggood.com/KST-A15-1810-7_4V-18kg-42g-High-Torque-Metal-Gear-Digital-Coreless-Servo-For-RC-Airplane-p-1462771.html
Description:
Brand Name: KST
Item Name: Coreless servo
Item NO.: A15-1810
Case Material: Aluminum Alloy
Motor Type: Coreless
Gear Set Material: Phosphor Bronze + Hardened Steel
Position Sensor: Potentionmeter
Position Feedback: Optional
Shielded Connecting Cable: 26AWG
Dimension: 35.5x15x32.5mm
Weight: 42g
Operation Voltage(rated): 7.4V
Operation Voltage Range: DC 6.0V - 8.4V
Torque: [email protected], [email protected], [email protected]
Speed: 0.14sec/60@6.0V, 0.12sec/60@7.4V, 0.10sec/60@8.4V
Travel Angle: 50 when 1000-2000us
Operating Temperature Range: -10℃ ~ +65℃
PWM Command SIgnal:
Signal Voltage TTL-Level: HIGH: min.3.3V, max.5.0V
TTL-Level: LOW: min.0.0V, max.1.5V
Pulse Lengths 900-2100μs
Pulse Lengths for Position -50 /center/+50
1000μs/1500μs/2000μs
Resolution <2μs
English Manual, Click Here
Package Included:
1x KST A15-1810 Digital Coreless Servo
1x Accessories
May 06, 2019, 08:04 AM
Merch's Avatar
KST A15-2212 7.4V 22kg 52g High Torque Metal Gear Digital Coreless Servo For RC Airpl
https://www.banggood.com/KST-A15-2212-7_4V-22kg-52g-High-Torque-Metal-Gear-Digital-Coreless-Servo-For-RC-Airplane-p-1462772.html
Description:
Brand Name: KST
Item NO.: A15-2212
Shielded Connecting Cable: 22AWG
Dimension: 40.5x15x34mm
Weight: 52g
Speed: 0.15sec/60@6.0V, 0.12sec/60@7.4V, 0.11sec/60@8.4V
PWM Command SIgnal:
Pulse Lengths for Position -50 /center/+50 1000μs/1500μs/2000μs
Resolution <2μs
Package Included:
1x KST A15-2212 Digital Coreless Servo
1x Accessories
May 06, 2019, 08:07 AM
Merch's Avatar
KST A20-3813 7.4V 38kg 72g High Torque Metal Gear Digital Brushless Servo For RC Airp
https://www.banggood.com/KST-A20-3813-7_4V-38kg-72g-High-Torque-Metal-Gear-Digital-Brushless-Servo-For-RC-Airplane-p-1462768.html
Description:
Brand Name: KST
Item Name: Brushless servo
Item NO.: A20-3813
Motor Type: Brushless
Dimension: 40.5x20x38mm
Weight: 72g
Speed: 0.15sec/60@6.0V, 0.13sec/60@7.4V, 0.12sec/60@8.4V
PWM Command SIgnal:
Resolution <2μs
Package Included:
1x KST A20-3813 Digital Coreless Servo
1x Accessories
New Product KST Digital Servo For RC Models alex_nikiforov Banggood.com 7 May 14, 2019 11:32 AM
New Product New KST MS320 Digital, Metal Gears, Hi-Speed & Torque Servo hobbyclub Electric Heli Talk 26 Mar 12, 2019 10:06 AM
Question Solar Servo D770 High Voltage Low Profile [email protected] Digital Metal Gear 47g Aero12 Radios 0 Mar 07, 2013 10:06 PM
