This thread is privately moderated by Mugin UAV, who may elect to delete unwanted replies.
May 05, 2019, 08:44 PM
New Product
Mugin-3 3600mm H-Tail Fiberglass VTOL UAV White Version
The Mugin fiberglass VTOL now comes with different colors. Here it is an example for Mugin 3600. All the same setup, but one more choice for the color. You can choose the normal blue gray version of Mugin 3600, or this white version.
Link: https://www.muginuav.com/product/mug...white-version/
This is a new version of Mugin 3600 VTOL UAV. We have changed the main material from wood to fiberglass, so as make the plane more durable and much lighter. The empty weight of previous version was 14.6kg, but this fiberglass version is 13kg only. You are now able to carry more equipment with the flight.
The Mugin 3600mm is the aircraft with the vertical take-off and landing (VTOL) function that can hover, take off, and land vertically. The platform caters to larger UAS projects such as universities or commercial projects. This aircraft is capable of carrying a wide variety of payload configurations and offers extended flight times. It is an exceptionally large aircraft designed for professional use and can be equipped with a full system of advanced control electronics to run in sync with the most advanced ground stations. This plane can get most anywhere, and perform most any job-related task you may require.
Specifications:
Dimensions
Wingspan: 3530mm
Length: 2420mm
Wing Area: 132dm2
Payload Bay: 560mm x 260mm x 270mm
Weight and Payload
Empty Weight: 13kg
Empty Weight with ARF Package: 29.8kg
Maximum Take-off Weight: 35kg
Payload Capacity: 5 to 8kg
Flight Characteristics
Cruise Speed: 75mph/120kph
Maxium Speed: 100mph/160kph
Stall Speed: 25mph/40kph
Maximum Flight Time: 3 hours
Range: Restricted to Flight Time
Packaging Information
Shipping Dimensions of Package: 160cm x 51cm x 50cm
Package Weight: Volumetric Weight of 82kg
Discussion Mugin-2 Pro 2930 Full Carbon Fiber VTOL Mugin UAV VTOLs 30 Jun 30, 2019 09:33 PM
New Product Mugin 4720mm Full Carbon Fiber VTOL Mugin UAV VTOLs 0 Dec 03, 2018 04:22 AM
Discussion Tail Sitter VTOL UAV mlbco VTOLs 54 Jan 09, 2011 10:24 PM
Discussion Aerovironment plans VTOL version of Wasp UAV hg1 VTOLs 2 Sep 11, 2007 09:51 PM
