Portchiavi F5J/F3X Plane Holder
Here's a cool plane holder for large F5J or F3X type sailplanes. Check it out...
Holds 2 Big Boy Planes
Here's a cool plane holder for large F5J or F3X type sailplanes. The holder can handle two planes and it has been designed so that the tail section of the lower plane won't interfere with the tail of the upper plane. That allows you to store and secure two models without worry. It's nice to be able to get your planes off the ground as they are less likely to get damaged and it keeps the bottom of the plane from getting wet on those early morning contest days.
The plane holder is made with lightweight materials that sounds like it is waterproof or at least water-resistant and it comes in a nice white finish with rubber strips to protect the wings. There are three cross bars that attach with wing nuts so it will be easy to break down and pack away when not in use. You can pick up one of these stands for 39.00.
Check out the Portchiavi F5J/F3X Plane Holder Here
May 06, 2019, 11:53 AM
I Ordered one and one cg machine.
Discussion Aero towing F3x planes tiju000 Scale Sailplanes 4 Feb 26, 2017 10:53 PM
Discussion F5J plane concept marc.pujol Electric Competition Soaring-F5J/ALES/e-Soaring 80 Jun 23, 2016 09:30 AM
Whoops! F3X Plane for Sale - Cheap David Olson Multi Task F3X 35 Nov 12, 2015 07:22 AM
Discussion F3X - Indoor Pattern Plane Tim H. Indoor Pattern/F3P 88 Sep 09, 2011 06:22 PM
Discussion What would be good all rounf F3x plane Lite2bolt Multi Task F3X 6 Sep 13, 2008 06:17 PM
