May 05, 2019, 04:56 PM
3D planes designer
Carletto73's Avatar
GASB Three
Hi,
after my previuos models GASB One and GASB Two, I would like show you my new design
This model is powered by a pusher motor with propeller. It accepts several motor, I suggest a Sunnysky X2216 2400kv. It is very cheap since it needs 750g of PLA, a very low cost motor and ESC. The speed of the model it very high. A key point of this model is that almost all the parts are fixed together by screws. This makes the assembly and disassembly of the model very easy and fast. In the event of a crash, repairs are very simple because no glue is used and being completely removable it is possible to print only the damaged part.
Installation manual available here
Here the video
GASB Three (6 min 24 sec)
...and here
GASB Three - recorded by Mavic Air (1 min 1 sec)
Particular attention has been paid to the seat of the screws in order to make the assembly very robust
In addition was provided 3mm carbon rods, to help to allign perfectly the parts avoiding mistake
Detail of the servo
The weight in order of flight is around 1200g
If you like my model support me
My supporters can download the GASB Three and all my contents even the future ones !!!
May 05, 2019, 05:01 PM
3D planes designer
Carletto73's Avatar
In attached some pictures make during the assembly
May 06, 2019, 06:34 AM
Thoemse's Avatar
Reminds me of the Northern Pike from local fiend a bit. That one is a great flier.
This seems to be very user friendly designed. Shorter control rods than the pike wich is good. Your canopy lock system is very nice too.
I allways wanted to print a GSB Two but I want to hand launch. I might give this one a go once I am through with my current projects. Thanks a lot for sharing your great designs carletto.
May 06, 2019, 10:18 AM
Ghost Rider the pattern's full
santanig5's Avatar
Cool design, will have top keep this one in mind.
Sent from my SM-G960U using Tapatalk
May 07, 2019, 05:54 PM
3D planes designer
Carletto73's Avatar
G3 ready
May 07, 2019, 07:08 PM
santanig5's Avatar
Originally Posted by Carletto73
G3 ready
Nice, have any flight videos?
May 11, 2019, 06:20 PM
3D planes designer
Carletto73's Avatar
The video is coming. Maybe tomorrow
This is the trailer
Real Ready To Fly
May 12, 2019, 02:36 AM
3D planes designer
Carletto73's Avatar
Here we are !
Yesterday was a good day to test the GASB Three despite the windy day. It flies very well,
Fast and bad !!!
Here the video
May 12, 2019, 11:17 AM
santanig5's Avatar
May 13, 2019, 03:22 PM
Charles Sherman
csherman's Avatar
How easy is it to hand launch on of these?
May 13, 2019, 04:00 PM
3D planes designer
Carletto73's Avatar
This model is quite new so I've not made much experience yet. I don't like launch by hand since with catapult I'm more confidente and I can pilot better. In any case should be easier that GASB Two, that, with less thrust and more wing loading is frequently launched by hand. For example see this video or this.
I think also that can depend by the motorization. If you use a motor X2216 2400Kv with 1,8Kg thrust maybe should be easy
May 14, 2019, 12:58 AM
Hey Carletto.
I start to print Gasb three but could not find the last part of the body where you put the motor on and the servo covers.
Ver y cool was that you don't need glue. Very cool project.
Thx for that
Dennis M.
May 14, 2019, 11:37 AM
3D planes designer
Carletto73's Avatar
Originally Posted by Corpse
Hey Carletto.
Thx for that
Dennis M.
You are right,
thanks for your comment.
I've just fix. Now you can download all parts
May 14, 2019, 11:38 AM
Thanks.
Gesendet von meinem VOG-L29 mit Tapatalk
May 16, 2019, 11:54 AM
3D planes designer
Carletto73's Avatar
A flight of GASB Three recorded by a Mavic Air
Discussion GASB Two - The first fan jet fully printed Carletto73 3D Printed Planes 44 Aug 18, 2019 10:51 AM
Discussion GASB One - Flying wing (ONLY 9 PIECES GLUELESS) Carletto73 3D Printed Planes 79 Aug 03, 2019 04:08 AM
Build Log GASB Two - Fan Jet 60cm wingspan Carletto73 Foamies (Scratchbuilt) 12 Mar 12, 2018 11:58 AM
Build Log Nano GASB Two - Fan Jet 45cm wingspan Carletto73 Foamies (Scratchbuilt) 2 Jan 27, 2017 10:18 AM
Discussion GASB Two - The first fan jet fully printed in the world Carletto73 3D Printing 6 Nov 21, 2016 03:57 PM
