This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
May 05, 2019, 05:25 AM
FPV addict
mlilasic's Avatar
Mini-Review
Review (ip) of Eachine ATX03S 5.8GHz 40CH 25mW/50mw/200mW Switchable FPV Transmitter
Review (ip) of Eachine ATX03S 5.8GHz 40CH 25mW/50mw/200mW Switchable FPV Transmitter Smart Audio Mic for RC Drone
Successor to ATX03 is here with addition of smart audio and mic.
Description:
  • Output power: 25mW/50mW/100mW/200mW adjustable
  • Input voltage: 3.3V-5V
  • 5V camera supply, 245mA(MAX)[email protected] (Typical)
  • 5V camera supply, 310mA(MAX)[email protected] (Typical)
  • 5V camera supply, 390mA(MAX)[email protected] (Typical)
  • 5V camera supply, 517mA(MAX)[email protected](Typical)
  • Video format: NTSC/PAL
  • Antenna dimensions: 55mm X 2mm diameter
  • Antenna: IPEX
  • Size: 19x16mm(LxW)
  • Frequency: 5.8GHz 5 bands 40 channels
  • Weight:
Features:
  • Support 0.01mw Parameter-adjusting Mode.
  • 25mW, 50mW, 100mW and 200mW power switchable.
  • One button frequency and power setup.
  • OSD configuration using smart audio.
  • With mic.
Button control channel select mode Channel select
Select 8 channels by simple short presses.
Green LED light on stands for CH1,short presses to change 8 channels sequentially.
For CH2/3/4/5/6/7/8, Green LED flicker once it won't light on
Notice: Green LED only light on for CH1.
Band Select
Press button for 2s,Red LED will flicker,then short presses to select 5 band A/B/E/F/r sequentially.
Notice: Red LED1 only light on for Band A.
Power select
Press button for 4s,Blue LED will flicker,then short presses to select power 25mW/50mW/100mW/200mW sequentially. For 50mW/100mW/200mW, Blue LED flicker once, it won't light on
Notice: Blue LED only light on for 25mW.
Pit Mode(0.01mW)
While in Pit Mode you can change channels and set power levels, but none of these changes will take effect until you quit Pit Mode. By default, Pit Mode will send a very weak signal
In the box:
1 x FPV Transmitter
1 x IPEX antenna
1 x Cable
1 x Instruction
Grab yours ATX03S HERE
May 05, 2019, 05:27 AM
FPV addict
mlilasic's Avatar
res
New Product Eachine ATX03S 5.8GHz 40CH 25mW/50mw/200mW Switchable FPV Transmitter - Free Testing BGKevin FPV Equipment 24 May 27, 2019 05:23 AM
New Product Eachine ATX03 Mini 5.8G 72CH 0/25mW/50mw/200mW Switchable FPV Transmitter-FREE TEST BG Tobey FPV Equipment 71 Mar 16, 2019 07:15 PM
New Product AKK X5 5.8Ghz 40CH 25mW/50mW/100mW/200mW Switchable FPV Transmitter Jay 123 FPV Equipment 4 Sep 27, 2018 05:34 AM
