May 24, 2019, 02:22 PM
Tim B.'s Avatar
Thanks Sylvain !
May 24, 2019, 02:29 PM
Tim B.'s Avatar
The rain Finally stopped, time to paint the hull
The rain Finally stopped, have been waiting for days.
Got the anti - roll chines made up and attached, the deck beams were continued forward beyond the point where they will be needed.
The hatch openings were defined and the border for the coaming is also ready.
Got a coat of primer on, ( Finally !!! )
May 24, 2019, 04:52 PM
Gravman's Avatar
Got a seamless fit on the anti roll chines. Were they a kit part or did you make them? Are they through bolted to the hull?
Latest blog entry: Myrtle Corey
May 25, 2019, 09:44 AM
Rmay's Avatar
X2 - nice, clean work.
May 25, 2019, 07:04 PM
Sylvain's Avatar
Already primed! This is going along really fast! Well done Tim.
May 25, 2019, 08:39 PM
Tim B.'s Avatar
Rain clouds on the horizon
Thanks everyone ~
The two day paint window is already closed, it will be next week before it opens again.
Just as well, time to put in the aft deck sections and get a start on the visible part of the work deck walls ~
Some builders go with using filler ( and sanding forever without ever getting a smooth surface ) and some cover the rough fiberglass with panels.
Panels make sense here so .020 sheet styrene is used ( later bulwark supports will be added ).
The diamond plate from Hobbylinc arrived, the O scale looks good so that will be used to create that parts of the real boat that use this type of plating.
http://www.hobbylinc.com/cgi-bin/s8....=diamond+plate
May 25, 2019, 09:14 PM
Rmay's Avatar
What are you using to glue the styrene to the fiberglass hull?
May 26, 2019, 09:27 PM
Tim B.'s Avatar
Thanks Sylvain !
May 28, 2019, 11:33 PM
Tim B.'s Avatar
Rough bar crossing
They chines were not included ~
Surely they will help with stability though during any rough bar crossing......
Vid done by geoffmackley:
Incredible video - fishing boats in rough sea (7 min 28 sec)
May 30, 2019, 05:37 PM
Tim B.'s Avatar
More paint
Gravman, the chines were mounted with Loctite construction adhesive Then drilled and pinned with brass rod in 4 places.
Some painting done, the blue for the lower half of the hull was put on this afternoon.
May 31, 2019, 12:47 PM
Tim B.'s Avatar
Traps
Originally Posted by Rmay
Thanks for the complement Tim. But I learn more than I ever display on RC Groups!
You are right !
While the hull is drying, some time will be spent on the traps ( creels ), Jerome Morris was kind enough to mail me some Great expandable netting that looks Perfect for making the traps ~
The real boat uses catch traps ( round top ) and live lobster storage traps ( flat top), will try to make a few of both.
Captain of the Eilean reports:
"Working 850 creels just now turned over every 2 days. Worked in strings of 25. Generally 10-12 hours to haul 400 depending on how far from home we are working, so we get home each evening."
The MBD built model in the last picture shows the configuration for this build.
Jun 01, 2019, 08:01 AM
Sylvain's Avatar
That shade of blue looks awesome. Very well done. Can't wait to see the red!
Jun 01, 2019, 12:00 PM
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
Tim,
You are a building machine! Nice work and hope we can meet sometime. Maybe in SF or LA for an event.
DH
Jun 01, 2019, 04:58 PM
Tim B.'s Avatar
Thanks to BobSF for the hull !
CaptDH, as you say in your Blog, "GET BACK IN THE SHOP !"
No time like the present to Build a model !
Jun 04, 2019, 07:12 PM
Tim B.'s Avatar
Loctite construction adhesive along with brass pins ...
Discussion Monterey Clipper Fishing Boats ........ Tim B. Scale Boats 163 Jan 19, 2018 04:01 PM
Build Log Beginner Vac U Tug Jr Fishing boat and Recovery Boat Build Update: Caught First Fish f.a.r.m.e.r Scale Boats 70 May 26, 2016 06:10 AM
Cool DJI Phantom 3 Ocean Flight To Fishing Boat UAFDRONE Multirotor Drone Talk 0 Apr 27, 2016 10:38 AM
Discussion Fishing Boats in Rough Sea - Crossing the Columbia bar Tug Hercules Dock Talk 9 Apr 01, 2016 10:47 AM
