Aug 28, 2019, 02:37 AM
jofro
I always prefer to fly all my helicopters with minimal head speed. It speed up after 3-4min. flight time to my ideal head speed, I normally fly this model 8-10 minutes on full tank.
Sep 20, 2019, 04:39 AM
jofro
Perfect day out with "XCell".
Sep 20, 2019, 08:52 PM
jofro
Latest footage.
2019 0920 163920 029 (3 min 1 sec)
(XCell short demo)
Sep 25, 2019, 12:44 AM
jofro
Perfect day out with "X/Cell" today, 7 models under my command! What a day!
Sep 25, 2019, 03:35 AM
jofro
After my recent replacement of stripped starting adapter it took only few more flights to strip down my starter shaft/wand!
I just can't believe I can't get the part in this country. Look like the IC models are becoming bit of the history.
Nevertheless, while in the local h/ware store store after my flying today I found this ideal set of ext. allens that will do the job after a minor mod.
Sep 27, 2019, 04:16 AM
jofro
Different day, different field with my good old X/Cell.
Sep 27, 2019, 04:06 PM
Starter bearing
I had one that I wore out too. I found a replacement at BOCCA BEARING. I wore that one out too so I guess I'm going to give them another try. Hope this helps you and me because I've got 2 Minature Aircraft X-L 60 Customs with a ton of upgrades setting on my bench that I can't start. I haven't flown a 700 size heli but I bet they don't fly any smoother than these. I've got to hurry and get at least one of these going because I've got a Bell 222 fiber glass body to put on one.
Sep 28, 2019, 05:29 AM
jofro
What do you mean by starter bearing? Did you wear out/stripped the start shaft addaptor?
Do you use the anti-vibration upgrade bearing block or the original block bearing which has to be very accurately assembled to minimize motor shaft vibes.
These IC models are becoming bit of a history now days, hard to get anything in parts.
I had also nice "222" with 60 size Pro Mech. in it, I gave it away 6 years ago for 'peanuts' just to unload 50+ models when downsizing the house.
The bloke still hasn't flown it, it's probably seized by now!
2019 0927 160848 038 (1 min 54 sec)
(XCell run) short part of my yesty's flight.
Oct 01, 2019, 03:09 PM
starter bearing
I used the flexible starter ( wand ) with a one way bearing in the end that you would slide it over a 6 mm shaft and start it like that. I'm guessing this isn't what you use. I'm sorry if I misled you but if you do use that now you know where to get one of those bearings.
Soinks
Oct 04, 2019, 03:33 AM
jofro
I can't imagine using flex start wand on my model where I need some 25cm extension.
While flying today at my home Club I have used for the first time my modified made up Allen key shaft, for a change it kicked on first turn. Hope it will last!
Oct 07, 2019, 12:34 AM
jofro
Long weekend down here, daylight saving is on, for another magic day with "X/Cell".
Discussion MA X-Cell Pro-1 with YS F-91AC. Bunjas Fuel Heli Talk 1 May 10, 2019 05:35 PM
Discussion Resurrecting a 1987 X-Cell 60 the496rocket Fuel Heli Talk 4 Nov 21, 2018 04:26 PM
Discussion MA X-Cell .60 Sweetrex Fuel Heli Talk 5 Apr 04, 2013 04:59 PM
Discussion 900 mA into 400 mA 4-cell NiMH receiver packÖ mechmove Batteries and Chargers 2 Jun 21, 2008 10:02 AM
60 mA lipo, X-twin propulsion and .4 gram micro ACT's RNAF Scratchbuilt Indoor and Micro Models 10 Nov 02, 2005 08:16 AM
